Problems with Idle
08-08-2007, 09:36 AM
Problems with Idle
Best to check/eliminate the most common cause, before you go chasing
other possibilities. Take the air intake ducting off the engine so you can
see the throttle butterfly. Run the engine, and when the idle is hunting up
and down, cover the idleup valve port with your finger (its the large hole
at the bottom on the inside of the throttle body, close to the butterfly).
If the hunting stops, and the idle drops to some lower and constant rpm,
then the idleup valve is at fault, and needs replacing. If the hunting does
not stop, then the cause is something else Confused
Note that there is a second large port higher up inside the throttle body
that vents crankcase fumes, and a small port for the idle speed adjusting
screw. Neither of these is connected with the idleup valve.
Cheers... jondee86
  No idle below 2000 rpm rich running Steller Engineering 3 2,798 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Engine starts/revs but no idle GenkiMotors 17 11,421 11-20-2021 04:12 AM
Last Post: GenkiMotors
  Big wheel problems gh0st 16 12,159 11-15-2021 10:51 PM
Last Post: gh0st
  Starting problems 4-AGE kouki Hanzo 3 3,991 08-31-2021 06:20 PM
Last Post: totta Crolla
  exhaust odor/idle MOT issue Ryo 7 9,664 07-15-2019 09:17 AM
Last Post: jondee86
