Project from Denmark
12-23-2012, 08:30 PM
Post: #31
I still have a ae86
http://www.bjerre-rally.dk |
12-24-2012, 08:30 AM
Post: #32
Den ser da find ud den hvide, er det en ren Zenki model?
Restoring my AE86, all the way... Going JDM style ![]() http://www.aeu86.org/viewtopic/ae86/p/150463#150463 |
12-26-2012, 11:28 PM
Post: #33
Den er fra 84 så frontgril er ikke original
12-27-2012, 07:52 AM
Post: #34
Hehe, stod og kiggede på den blå coupe, til sprint for nogle måneder siden på falster. så godt skaringen, og tænkte om det var træ, eller sten den havde taget.
01-12-2013, 12:00 PM
(This post was last modified: 07-07-2017 10:09 PM by Vaptor.)
Post: #35
Time for some more news from my project. Have removed all parts from the red one, so that I can start work on my own, on the rear.
![]() Started to remove the roof skin, cleaned the area where the two plates were assembled, so that I could see all the spot welds. ![]() When I removed the windshield, I could see several places where there it had rusted... Always a surprise with some new rust. ![]() ![]() Decided to remove the rust, while til roof skin still where attached to the shell. This it would not come out shape, and when I remove the skin, its easily to paint the underside of the roof ![]() ![]() The previous owner, had cut away some of the roof, so there a big hole, that has to closed... ![]() Luckily I had saved the roof from my own car, and could cut the missing piece from it. ![]() ![]() Unfortunately it had some damage, and it was covered with 5-8mm of filler, so used a lot of time to get it in to shape again, it still has some small dent in it. But that's a easy fix. Used some copper plate on the back side of the roof, so that the heat from the welding, wont bend the roof. ![]() After it was welded, and the welding was grinded down, I applied a layer of body tin with a heat blower. This is the correct way to do it, but as it was my first time, it took a lot of time to learn how to use it, but the end result is perfect layer of Tin. ![]() ![]() After a lot of hand sanding, you can see the area where the Tin has settled in, and the roof feels perfect ![]() ![]() Now I just needed to drill all the spot welds, and remove it from the shell, now I got a roof skin, with a Genuine Sun Roof. The sliding roof has some deep rust, and the Weatherstrip for Sun Roof Panel, won't fit anymore. So I have been so lucky, to find a brand new one in Japan. As Toyota don't have it anymore. 350 Euro with freight and Taxes not bad. ![]() ![]() Cut the shell in half, after roof was removed. ![]() Removed the rear quarter panel, to see how much of the inner panel could be used on my own. I was very happy to see, that there only where some minor rust on it, so now I can get a genuine inner panel on my car ![]() ![]() The rest of the shell, has been divided in to smaller pieces, by drilling the spot welds. Restoring my AE86, all the way... Going JDM style ![]() http://www.aeu86.org/viewtopic/ae86/p/150463#150463 |
01-12-2013, 01:16 PM
Post: #36
Very nice work mate!!
![]() You have 3 hachi in one car later, but that one car will be brand new, I love these restaurations. ![]() |
01-12-2013, 01:20 PM
Post: #37
Thanks. Yea it will almost take 3 shell's to put one together, still got a lot of part's left from the red.
![]() But it takes a lot of time to put the car back together again, but then I know it's all genuine part's that is used in the shell ![]() To bad you can't buy body part's anymore, still need some part's for the rear end... Can't find them anywhere ![]() Restoring my AE86, all the way... Going JDM style ![]() http://www.aeu86.org/viewtopic/ae86/p/150463#150463 |
01-12-2013, 01:27 PM
Post: #38
Yeah, it gets worse with normal parts to, looks like they are draining the stock and stopped making new parts.
01-12-2013, 08:34 PM
Post: #39
Think I am one of the persons that are draining Toyota for parts, bought a lot from them. Got a good deal from a Toyota dealer, and gets 25% discount on part's. So I was tempted
01-12-2013, 09:13 PM
Post: #40
Hehehe, well my car is done now so go ahead.
