Prothane Bushing Install Question
06-11-2011, 05:32 PM
I am in the process of installing the prothane bushing kit. I have a question about the lateral trackbar bushing. I pushed the rubber out I noticed there's a metal sleeve still in the trackbar. Do I need to push this metal sleeve out? The new bushings won't go in easily with the sleeve there but I think I could force them in.
Thanks
06-12-2011, 03:22 AM
Are you using the lube provided with the bushings? I´d maintain the sleeve, as it´s there to increase area andevenly spread the force over the bushing. Tight fit is needed Smile
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
06-12-2011, 04:01 AM
I am using the lube provided. The other bushings of this design I've done (only the front control arm ones) have just pushed in by hand. It looks like if I take out this sleeve the diameter is right that it would just push in by hand. But it's gonna be hard to push out the sleeve so that's why I'm asking. I don't want to do it if it's not necessary.
06-12-2011, 05:59 AM
That rubber bushing removed was originally bonded to that sleeve wasn't it??
The plastic bushing is a slip fit.
So what!
06-12-2011, 06:40 AM
Yes, the old rubber one appeared to be bonded to the metal sleeve.
06-12-2011, 06:12 PM
get rid of the sleeve.. (easier said than done though).
  CD player install. kazi 8 9,454 02-21-2017 11:57 AM
  How to install 20V ITB on 16V head Mr.komp 7 12,258 12-28-2015 05:35 PM
Last Post: pack
  alignment issues after re-install of coilovers NBU 21 19,970 08-03-2013 06:18 AM
Last Post: allencr
  bigport to smallport install sketchy 4 13,887 09-28-2012 10:24 AM
Last Post: totta Crolla
  T3 rack adaptor bushing TheGerman 4 6,815 03-09-2012 12:32 AM
Last Post: TheGerman
