Question.
10-15-2005, 01:10 PM
Question.
I was working on my hachi. (removing some old wires)
An than i noticed that i had a wire hanging loose. Can anybody tell me where this wire should be connected.? ![]() I also think this is verry strange. Does anybody know where this hose should go to? ![]() Tnx. ![]() ![]() ![]() ![]() Toyota MR2 2.0 16V Gen3 Turbo Toyota MR2 1.6 16V Toyota Corolla GTZ Twincam 1.6 16V (AE86) (Sold. ![]() Toyota Corolla GT Twincam 1.6 16V (My new project ![]() |
10-15-2005, 02:58 PM
Question.
CF,
that first picture is the cable for your oil pressure I think, if you look a bit down on the side of your block you should see your oil filter and near it some "bell" like looking thing with a small thing ontop of which this connector slides onto The hose the red arrow in the 2nd picture is correctly hooked up I think. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
10-15-2005, 03:32 PM
Question.
I found it, Tnx
![]() The problem with the airintake is that after i cleaned the aitintake the engine runs on 2000 rpm, without pushing the pedal. I thougt maybe i could be a vacuum problem. The air intake was reeeaaaal dirty (rally) but run normal. After cleaning, 2000 rpm. what could it be. ![]() Toyota MR2 2.0 16V Gen3 Turbo Toyota MR2 1.6 16V Toyota Corolla GTZ Twincam 1.6 16V (AE86) (Sold. ![]() Toyota Corolla GT Twincam 1.6 16V (My new project ![]() |
10-15-2005, 04:06 PM
Question.
cable adjustment/vacuum leaks I think..
10-15-2005, 09:40 PM
Question.
The hose you asked before goes to a sensor located on the OEM air-filter-box (i think it's an air-temp sensor...)
AE86 FANATIC!!! |
10-16-2005, 01:04 AM
Question.
alimonos Wrote:The hose you asked before goes to a sensor located on the OEM air-filter-box (i think it's an air-temp sensor...) Thats correct, and it wont cause such a high idle. It only increase/decrease by a few 100 rpms. Youtube Myspace and I´ll Google your Yahoo |
10-16-2005, 10:29 AM
Question.
OK tnx guys.
![]() I wont change the hose then. But what could couse the problem?? ![]() Toyota MR2 2.0 16V Gen3 Turbo Toyota MR2 1.6 16V Toyota Corolla GTZ Twincam 1.6 16V (AE86) (Sold. ![]() Toyota Corolla GT Twincam 1.6 16V (My new project ![]() |
10-16-2005, 12:38 PM
Question.
CF,
Does your idle stay at 2000 rpm or does it eventually goes down when the engine warms up? Because 2000 rpm idle on a cold engine is a normal.. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
10-16-2005, 12:46 PM
Question.
It starts with 2500 cold en when its warmed up it stays 2000.
Sometimes around 1700/1800 rpm. ![]() Toyota MR2 2.0 16V Gen3 Turbo Toyota MR2 1.6 16V Toyota Corolla GTZ Twincam 1.6 16V (AE86) (Sold. ![]() Toyota Corolla GT Twincam 1.6 16V (My new project ![]() |
10-16-2005, 03:46 PM
Question.
Have you tryed to adjusting the idle when engine is hot? I would try that if i were you.
![]() Youtube Myspace and I´ll Google your Yahoo |
