Question.
10-15-2005, 01:10 PM
Question.
I was working on my hachi. (removing some old wires)
An than i noticed that i had a wire hanging loose. Can anybody tell me where this wire should be connected.? I also think this is verry strange. Does anybody know where this hose should go to? Tnx. Toyota MR2 2.0 16V Gen3 Turbo Toyota MR2 1.6 16V Toyota Corolla GTZ Twincam 1.6 16V (AE86) (Sold. ) Toyota Corolla GT Twincam 1.6 16V (My new project ) |
10-15-2005, 02:58 PM
Question.
CF,
that first picture is the cable for your oil pressure I think, if you look a bit down on the side of your block you should see your oil filter and near it some "bell" like looking thing with a small thing ontop of which this connector slides onto The hose the red arrow in the 2nd picture is correctly hooked up I think. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
10-15-2005, 03:32 PM
Question.
I found it, Tnx
The problem with the airintake is that after i cleaned the aitintake the engine runs on 2000 rpm, without pushing the pedal. I thougt maybe i could be a vacuum problem. The air intake was reeeaaaal dirty (rally) but run normal. After cleaning, 2000 rpm. what could it be. Toyota MR2 2.0 16V Gen3 Turbo Toyota MR2 1.6 16V Toyota Corolla GTZ Twincam 1.6 16V (AE86) (Sold. ) Toyota Corolla GT Twincam 1.6 16V (My new project ) |
10-15-2005, 04:06 PM
Question.
cable adjustment/vacuum leaks I think..
10-15-2005, 09:40 PM
Question.
The hose you asked before goes to a sensor located on the OEM air-filter-box (i think it's an air-temp sensor...)
AE86 FANATIC!!! |
10-16-2005, 01:04 AM
Question.
alimonos Wrote:The hose you asked before goes to a sensor located on the OEM air-filter-box (i think it's an air-temp sensor...) Thats correct, and it wont cause such a high idle. It only increase/decrease by a few 100 rpms. Youtube Myspace and I´ll Google your Yahoo |
10-16-2005, 10:29 AM
Question.
OK tnx guys.
I wont change the hose then. But what could couse the problem?? Toyota MR2 2.0 16V Gen3 Turbo Toyota MR2 1.6 16V Toyota Corolla GTZ Twincam 1.6 16V (AE86) (Sold. ) Toyota Corolla GT Twincam 1.6 16V (My new project ) |
10-16-2005, 12:38 PM
Question.
CF,
Does your idle stay at 2000 rpm or does it eventually goes down when the engine warms up? Because 2000 rpm idle on a cold engine is a normal.. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
10-16-2005, 12:46 PM
Question.
It starts with 2500 cold en when its warmed up it stays 2000.
Sometimes around 1700/1800 rpm. Toyota MR2 2.0 16V Gen3 Turbo Toyota MR2 1.6 16V Toyota Corolla GTZ Twincam 1.6 16V (AE86) (Sold. ) Toyota Corolla GT Twincam 1.6 16V (My new project ) |
10-16-2005, 03:46 PM
Question.
Have you tryed to adjusting the idle when engine is hot? I would try that if i were you.
