Question about raising compression?
01-26-2005, 11:53 PM
Well I actually have a couple questions. What size is the stock head gasket on a 4-AGE? How much smaller of a head gasket do I have to install to actually make a performance gain?
Mulisha |
01-27-2005, 01:43 AM
I believe the stock gasket is 1.2mm. So anything lower would have some CR increase.
Broken down 1984 Trueno HB
01-27-2005, 03:06 AM
Yeah, thats the size I thought it was. Now if I lower it to .8 or something smaller than that I will see power increase and I shouldn't have to do anything to the ECU or tuning wise.
01-27-2005, 04:57 AM
I wonder how much performance you gain from increasing the compresion like this? like if you change to 0.8mm what will you gain in actuall performance?
01-27-2005, 10:38 AM
Try the 7A head gasket - the stock one is 0.7 mm.
If you change the CR - adjustable timing wheels might be good investment :-) I think that you will be close to 10:1 CR. A little performance gain - maybe 3-5 hp maximum. But for cheap ;-) |
01-27-2005, 07:18 PM
Would I have to get adjustable cam gears?
01-27-2005, 07:46 PM
No
01-27-2005, 08:10 PM
2 Mulisha:
Not obligatory, but will help. When you mill the head (and/or use thinner gasket) you will retard your cams timing. With adjustable wheels you can fix this problem (also when you use different cams) and adjust the timing "1/2 tooth" - for example. |
01-28-2005, 02:04 AM
Would installing a smaller head gasket really retard the timing that much.
01-28-2005, 09:13 AM
I once calculated the timing difference with shaved head etc, and I came to about 0.0xx degrees, so REALLY negigeable! thats some 200 bucks for cam gears you can save...
| 82mm Stock compression Pistons | apardal | 4 | 4,640 |
| working out compression ratios | kazi | 2 | 5,042 |
07-16-2019 08:22 PM Last Post: oldeskewltoy |
| Raising the rev limit on stock ECU | fax0815 | 2 | 12,888 |
08-31-2015 02:04 PM Last Post: gon |
| What is cranking compression on 10-1 4AGE? | oldeskewltoy | 2 | 5,991 |
03-24-2015 10:18 AM Last Post: ditn |
| What fuel are you high compression guys running? | 4000GT | 18 | 21,160 |
09-04-2011 07:11 PM Last Post: IBMFD3S |
