Question about raising compression?
01-26-2005, 11:53 PM
Well I actually have a couple questions. What size is the stock head gasket on a 4-AGE? How much smaller of a head gasket do I have to install to actually make a performance gain?
Mulisha
01-27-2005, 01:43 AM
I believe the stock gasket is 1.2mm. So anything lower would have some CR increase.
Broken down 1984 Trueno HB
[Image: AEU86 AE86 - Question about raising compression?]
01-27-2005, 03:06 AM
Yeah, thats the size I thought it was. Now if I lower it to .8 or something smaller than that I will see power increase and I shouldn't have to do anything to the ECU or tuning wise.
01-27-2005, 04:57 AM
I wonder how much performance you gain from increasing the compresion like this? like if you change to 0.8mm what will you gain in actuall performance?
01-27-2005, 10:38 AM
Try the 7A head gasket - the stock one is 0.7 mm.
If you change the CR - adjustable timing wheels might be good investment :-)
I think that you will be close to 10:1 CR. A little performance gain - maybe 3-5 hp maximum. But for cheap ;-)
01-27-2005, 07:18 PM
Would I have to get adjustable cam gears?
01-27-2005, 07:46 PM
No
01-27-2005, 08:10 PM
2 Mulisha:
Not obligatory, but will help.
When you mill the head (and/or use thinner gasket) you will retard your cams timing. With adjustable wheels you can fix this problem (also when you use different cams) and adjust the timing "1/2 tooth" - for example.
01-28-2005, 02:04 AM
Would installing a smaller head gasket really retard the timing that much.
01-28-2005, 09:13 AM
I once calculated the timing difference with shaved head etc, and I came to about 0.0xx degrees, so REALLY negigeable! thats some 200 bucks for cam gears you can save...
  82mm Stock compression Pistons apardal 4 2,739 11-24-2021 04:26 PM
Last Post: apardal
  working out compression ratios kazi 2 3,521 07-16-2019 08:22 PM
  Raising the rev limit on stock ECU fax0815 2 10,730 08-31-2015 02:04 PM
Last Post: gon
  What is cranking compression on 10-1 4AGE? oldeskewltoy 2 4,685 03-24-2015 10:18 AM
Last Post: ditn
  What fuel are you high compression guys running? 4000GT 18 16,140 09-04-2011 07:11 PM
Last Post: IBMFD3S
