Question on Rod Bearings
03-18-2020, 02:12 AM
Hey everyone, I have a question that I hope you can help me. I am replacing my rod bearings and it looks like I have the wrong ACL ones. I have the early type 40mm crank with the 18 pin size, not the 20 size.
So I am trying to figure out which bearings (ACL, King, etc) is the correct one to get because the set I purchased from MRP doesnt work. Let me know. Thank you!
03-18-2020, 05:53 PM
Any chance you have access to Rockauto??
https://www.rockauto.com/en/catalog/toyo...aring,5212
Dan -
03-18-2020, 06:01 PM
(03-18-2020 05:53 PM)oldeskewltoy Wrote:  Any chance you have access to Rockauto??
I do. which one do I need to get? or any of them?
03-19-2020, 03:46 AM
Toyota bearings are also still available.... what I would do... is get the crank journals measured before you buy bearings... all the journals... - Why? you might just order (ask your machinist first) oversize bearings and machine the crank to fit the tolerance you want. Tolerances are in the FSM
Dan -
  Emergency help find store with bearings france Allexz 5 4,642 09-12-2019 03:24 PM
Last Post: Allexz
  Diff bearings izanagi 11 15,896 07-05-2014 07:29 PM
Last Post: assassin10000
  Top mount bearings totta Crolla 1 3,743 01-22-2014 11:33 AM
Last Post: totta Crolla
  Which new bearings for ae101 4AGZE crankshaft&connecting ditn 4 7,113 10-31-2013 06:04 PM
Last Post: ditn
  Diff bearings Hachi-man 4 5,307 11-14-2012 07:04 PM
Last Post: McKenney
