Question.
10-16-2005, 03:53 PM
Question.
No.
Im still learning about engines and cars.
That means that i dont know how to do that.
I never got engine failures with mij MR2 so i never tryed a thing like that.
But some explaining would be nice. Cool
Bring it on.
[Image: AEU86 AE86 - Question.]
Toyota MR2 2.0 16V Gen3 Turbo
Toyota MR2 1.6 16V
10-16-2005, 03:56 PM
Question.
The idle screw is under a black rubberplug on throtle housing
10-16-2005, 04:00 PM
Question.
Great tnx i will look for the screw right away.
As soon as my muffler is back on i will try it.
Toyota MR2 1.6 16V
10-16-2005, 04:01 PM
Question.
Lets us hear how it works out for you Smile
Question.
I will. Thumbs up!
Toyota MR2 1.6 16V
10-20-2005, 03:42 PM
Question.
alimonos Wrote:The hose you asked before goes to a sensor located on the OEM air-filter-box (i think it's an air-temp sensor...)
It is not a sensor - it's an actuator.
It opens to allow more air when you turn on lights or similar device in order to compensate the load on the alternator and the RPM drop.
AE86 GTS '84 Red Top
10-20-2005, 09:23 PM
Question.
How can i make this actuator work all the time? I need some more rpm when idle... :wink:
10-21-2005, 09:05 AM
Question.
alimonos Wrote:How can i make this actuator work all the time? I need some more rpm when idle... :wink:
1. Bypass it Evil
2. Connect one of the tapped openings on the trottle body to the other opening on the filter box. Even better - you can add manually controlled VISV - from a junkyard toyota. just take it with the connector and install it. It may look a little bit different if newer model but the function is the same.
Bluetop has two VISVs - one on the filter and one controlling the TVIS.
Redtop Small port also has two - one on the filter and one controlling the fiel pressure regulator.
10-21-2005, 01:08 PM
Question.
I have no filter box ... Dumb question I use a Sparco filter instead...
So what am i supposed to do to by-pass it?
10-21-2005, 03:38 PM
Question.
alimonos Wrote:I have no filter box ... Dumb question I use a Sparco filter instead...
You can take air from the tube before the trottle body and connect it to one small vacuum openings on the TB.
If you show me a photo maybe i can give you some ideas.
User(s) browsing this thread: 18 Guest(s)
