Question.
10-21-2005, 06:57 PM
Question.
hi my engine run to high
it's make around the 3000 rpm when it is hot i have no vacum leak do someone know what it is ? |
10-21-2005, 10:28 PM
Question.
Just bring it to Jasper...he'll have it fixed long before we guess what the problem is. Maybe the throttle cable is not adjusted correctly?
10-21-2005, 10:29 PM
Question.
here is a photo Bad Dog ...
http://www.aeu86.org/download.php?id=2478 AE86 FANATIC!!! |
10-21-2005, 11:38 PM
Question.
no jasper dont kwow what it could be
i thing that it is something whit the cold start intake before the (gasklep) dont know the english word for that |
10-22-2005, 01:01 AM
Question.
gasklep is throttle valve
No idea what it could be though.. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
10-24-2005, 12:52 PM
Question.
Chell Wrote:no jasper dont kwow what it could be Remove the rubber btw filter box and trottle body (TB). Start the warmed engine. If it keeps RPM high start closing the small front openning of the TB. It might me hot there. If the engine stops - you have no vacuum leaks, otherwise - you know what to do. If the problem is in the cold start valve - remove it and check it. It might need cleaning or ( replacing. Good luck AE86 GTS '84 Red Top |
10-24-2005, 12:54 PM
Question.
alimonos Wrote:here is a photo Bad Dog ... If you have good welder aroung you you'd better make a hole and weld a small tube ot the metal part. Then connect it with the opening on the TB. Or simpli use secong "mini" filter for the vacuum line. AE86 GTS '84 Red Top |
User(s) browsing this thread: 15 Guest(s)
