Questions about brake boosters and master cylinders---SOLVED
12-27-2011, 10:31 PM
Hi mates looking "google pics" i saw this:
Anybody know what brake booster and master cylinder is that? I heard that Honda Insight's booster can be fitted in our cars...Anybody know if it's true and what size is this master cylinder? (my car mounts 4 pistons wilwood brake calipers, but her zenki master cylinder is a bit small) Other solution for those calipers? Thanks! Cheers, Tomi |
12-27-2011, 11:09 PM
It´s a KP6* in the picture and cause of that it´s the genuine KP brakebooster same with the brake master cylinder.
I´d personally whouldn´t use them, very tiny booster and small diameter master cylinder! Can´t help with your other questions, sorry... 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
01-21-2012, 11:49 AM
fax0815 Wrote:It´s a KP6* in the picture and cause of that it´s the genuine KP brakebooster same with the brake master cylinder. I didn't notice the panel!! hahaha! i was thinking it was a 86 engine bay ok mate...this isn't the solution :wink: Anybody know any booster for 4 pistons calipers?? |
01-21-2012, 01:45 PM
IMHO you should be able to stick with the original brake booster and just change the BMC to something bigger to accommodate the willwood 4pots.
what bolt pattern do you have as there are different ones? AE86 ex-daily |
01-21-2012, 01:57 PM
If you have the standard horizontal 2 bolts BMC-> many nissan (like the R32 GTS) , many toyota 4X4 (landcrusier) some Mitsubishi...
Seriously you have many options By the way it would be cool to make a complete list of BMC that can be used depending on the booster (On AE86 we have 3 different types: 2 bolts straight, 2 bolts inclined, 4 bolts) and the bore size of each |
01-21-2012, 03:09 PM
4 bolt is 7/8 the others are 15/16 if I'm not mistaken - as far as I'm aware the 4 bolt is rather rare and apparently also used on the 4runner (US Hilux version) but not on the regular Hiluxs and Land Cruisers
AE86 ex-daily |
01-21-2012, 03:20 PM
As above R32 non-abs will work + some Hilux options.
The R32 is front is a 3 line type, Front left/right & rear An 86 is for Life, not just for Christmas |
01-21-2012, 03:26 PM
What Wilwoods are you running?
I have the standard setup and so far its been fine. Maybe a little more travel then stock, but I find it makes the brakes easier to modulate when using grabby pads (personal preference). A wheel to steer the front of the car A pedal to steer the rear |
01-21-2012, 03:43 PM
Bean Bandit Wrote:4 bolt is 7/8 the others are 15/16 if I'm not mistaken - as far as I'm aware the 4 bolt is rather rare and apparently also used on the 4runner (US Hilux version) but not on the regular Hiluxs and Land Cruisers13/16 for the others (15/16 is what you want when you run 4 pots) |
01-21-2012, 05:01 PM
zenki is 3/4 and kouki is 7/8
i have them both over here zenki is 2 bolt and kouki 4 bolt (or the other way ) '87 levin coupé |
20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 2,541 |
Windscreen stoopid(?) questions.... | Mylesmck | 7 | 1,256 |
04-30-2024 09:46 PM Last Post: Mylesmck |
PWR light issue and no brake fluid after winter storage | magpie | 10 | 2,807 |
AE86 Driveshaft too long? [SOLVED] | MyCrazyGarage | 12 | 7,603 |
07-28-2022 10:48 PM Last Post: banpei |
Brake Bias Questions | mad.matt | 10 | 11,542 |
01-03-2019 04:54 AM Last Post: mad.matt |
