Questions about brake boosters and master cylinders---SOLVED
12-27-2011, 10:31 PM
Hi mates looking "google pics" i saw this:
[Image: AEU86 AE86 - Questions about brake boost...s---SOLVED]
Anybody know what brake booster and master cylinder is that?
I heard that Honda Insight's booster can be fitted in our cars...Anybody know if it's true and what size is this master cylinder? (my car mounts 4 pistons wilwood brake calipers, but her zenki master cylinder is a bit small)
Other solution for those calipers?
Thanks!
Cheers, Tomi
12-27-2011, 11:09 PM
It´s a KP6* in the picture and cause of that it´s the genuine KP brakebooster Smile same with the brake master cylinder.
I´d personally whouldn´t use them, very tiny booster and small diameter master cylinder!
Can´t help with your other questions, sorry...
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
01-21-2012, 11:49 AM
fax0815 Wrote:It´s a KP6* in the picture and cause of that it´s the genuine KP brakebooster Smile same with the brake master cylinder.
I didn't notice the panel!! hahaha! i was thinking it was a 86 engine bay Banging head ok mate...this isn't the solution :wink:
Anybody know any booster for 4 pistons calipers??
01-21-2012, 01:45 PM
IMHO you should be able to stick with the original brake booster and just change the BMC to something bigger to accommodate the willwood 4pots.
what bolt pattern do you have as there are different ones?
01-21-2012, 01:57 PM
If you have the standard horizontal 2 bolts BMC-> many nissan (like the R32 GTS) , many toyota 4X4 (landcrusier) some Mitsubishi...
Seriously you have many options
By the way it would be cool to make a complete list of BMC that can be used depending on the booster
(On AE86 we have 3 different types: 2 bolts straight, 2 bolts inclined, 4 bolts)
and the bore size of each Smile
01-21-2012, 03:09 PM
4 bolt is 7/8 the others are 15/16 if I'm not mistaken - as far as I'm aware the 4 bolt is rather rare and apparently also used on the 4runner (US Hilux version) but not on the regular Hiluxs and Land Cruisers
01-21-2012, 03:20 PM
As above R32 non-abs will work + some Hilux options.
The R32 is front is a 3 line type, Front left/right & rear
01-21-2012, 03:26 PM
What Wilwoods are you running?
I have the standard setup and so far its been fine. Maybe a little more travel then stock, but I find it makes the brakes easier to modulate when using grabby pads (personal preference).
01-21-2012, 03:43 PM
Bean Bandit Wrote:4 bolt is 7/8 the others are 15/16 if I'm not mistaken - as far as I'm aware the 4 bolt is rather rare and apparently also used on the 4runner (US Hilux version) but not on the regular Hiluxs and Land Cruisers
13/16 for the others Wink (15/16 is what you want when you run 4 pots)
01-21-2012, 05:01 PM
zenki is 3/4 and kouki is 7/8
i have them both over here Smile
zenki is 2 bolt and kouki 4 bolt (or the other way Dumb question )
'87 levin coupé
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 2,578 05-26-2024 07:40 PM
Last Post: totta Crolla
  Windscreen stoopid(?) questions.... Mylesmck 7 1,297 04-30-2024 09:46 PM
Last Post: Mylesmck
  PWR light issue and no brake fluid after winter storage magpie 10 2,839 05-25-2023 08:09 AM
  AE86 Driveshaft too long? [SOLVED] MyCrazyGarage 12 7,638 07-28-2022 10:48 PM
  Brake Bias Questions mad.matt 10 11,572 01-03-2019 04:54 AM
