RCA doubt
01-13-2007, 11:20 PM
RCA doubt
Hi folks, i have a doubt here about using or not the RCA.
In this moment i have konisport and apex springs (-4mm), but it seems me that the car didn`t lowered that much. The lower suspension arm is completely on horizontal position, that´s the right position? Do i need to put RCA 30mm or 40mm? Thanks. |
01-13-2007, 11:46 PM
RCA doubt
Read about the bump-steer fenomenon (use google). Then drive the car - if you notice it, use RCA's at least 30mm but no more that 40mm (if you lower the car 40mm).
01-13-2007, 11:48 PM
RCA doubt
dynamic geometry is a very important element of suspension and you shouldnt underestimate it :wink:
86ers.org AE86 x GXE10 |
01-14-2007, 12:05 AM
RCA doubt
Spitfire Wrote:dynamic geometry is a very important element of suspension and you shouldnt underestimate it :wink: I agree with you absolutely, but i want it to know before i put the car on the road only by the lower arm position. ![]() |
01-14-2007, 06:23 AM
RCA doubt
hinachyo Wrote:Spitfire Wrote:dynamic geometry is a very important element of suspension and you shouldnt underestimate it :wink: Put the RCA on, you'll feel a difference. (only if you've lowered the car 30mm+) Andrew |
01-14-2007, 11:07 AM
RCA doubt
Hmm..I once uploaded a picture that showed how negative camber was created during compression. Its somewhere in my image map on the site, but I don't know how to repost that pic.
Basically, horizontal A-Arms are a no-no, you'll get the tiniest amount of positive camber gain during compression and negative during droop. Throw those rca's in there and things should be better. A wheel to steer the front of the car A pedal to steer the rear |
RCA sizing | kazi | 3 | 4,844 |
01-28-2018 10:44 PM Last Post: kazi |
Kaaz width doubt, OEM is out of car | T_AE86 | 3 | 5,354 |
04-13-2013 12:05 AM Last Post: T_AE86 |
Cams doubt | T_AE86 | 47 | 54,570 |
02-12-2013 01:45 PM Last Post: Bean |
lowering - adj. panhard rod & rca's & panhard bushin | Apolan | 8 | 7,723 |
05-24-2009 10:20 AM Last Post: Apolan |
Doubt about TRD springs height | Rasteirinho | 14 | 19,815 |
09-03-2008 05:20 AM Last Post: assassin10000 |
