RCA sizing
01-28-2018, 12:24 PM
RCA sizing
Can anyone tell me the general rule when it comes to selecting an RCA size? Are you looking for the same RCA height as the amount you have dropped the car? IE lowered car by 50mm so should have 50mm RCA?
Looking at getting a set made up and he currently shocks 50mm but I'm thinking that's quite a big size for an RCA seeing as most are 38mm? |
01-28-2018, 02:33 PM
RCA sizing
It's a balance between amount of lowering, stiffness / shock travel and wheel clearance.
01-28-2018, 02:44 PM
RCA sizing
Toyota did a good job of getting the roll centres right so the best way to approach this would be to measure the TCA angle without RCA and at standard ride height then aim to get the same TCA angle once lowered with RCA fitted.
The steeper the TCA angle is the higher the roll centre will be and the stiffer the suspension will be in roll. An analogue brain in a digital World |
01-28-2018, 10:44 PM
RCA sizing
thanks for the feed back guys. will give it a measure and see
| lowering - adj. panhard rod & rca's & panhard bushin | Apolan | 8 | 9,598 |
05-24-2009 10:20 AM Last Post: Apolan |
| RCA question | Eric | 10 | 11,392 |
08-19-2008 10:18 PM Last Post: Eric |
| RCA doubt | hinachyo | 6 | 7,333 |
01-14-2007 11:07 AM Last Post: NoHachi |
| RCA in other cars? | Spitfire | 3 | 5,644 |
01-14-2007 06:27 AM Last Post: assassin10000 |
| RCA or NRCA | Rasteirinho | 5 | 10,017 |
04-17-2006 07:23 PM Last Post: Rasteirinho |
