RCA sizing
01-28-2018, 12:24 PM
RCA sizing
Can anyone tell me the general rule when it comes to selecting an RCA size? Are you looking for the same RCA height as the amount you have dropped the car? IE lowered car by 50mm so should have 50mm RCA?
Looking at getting a set made up and he currently shocks 50mm but I'm thinking that's quite a big size for an RCA seeing as most are 38mm?
01-28-2018, 02:33 PM
RCA sizing
It's a balance between amount of lowering, stiffness / shock travel and wheel clearance.
01-28-2018, 02:44 PM
RCA sizing
Toyota did a good job of getting the roll centres right so the best way to approach this would be to measure the TCA angle without RCA and at standard ride height then aim to get the same TCA angle once lowered with RCA fitted.
The steeper the TCA angle is the higher the roll centre will be and the stiffer the suspension will be in roll.
01-28-2018, 10:44 PM
RCA sizing
thanks for the feed back guys. will give it a measure and see
  lowering - adj. panhard rod & rca's & panhard bushin Apolan 8 7,713 05-24-2009 10:20 AM
Last Post: Apolan
  RCA question Eric 10 9,307 08-19-2008 10:18 PM
Last Post: Eric
  RCA doubt hinachyo 6 5,846 01-14-2007 11:07 AM
Last Post: NoHachi
  RCA in other cars? Spitfire 3 4,663 01-14-2007 06:27 AM
Last Post: assassin10000
  RCA or NRCA Rasteirinho 5 8,725 04-17-2006 07:23 PM
Last Post: Rasteirinho
User(s) browsing this thread:
