RE: mix and match the 4AGE..
01-18-2012, 07:02 AM
Hey guys,
Mental block I have here Going to use a small port block and a BT head.. The question. Which head gasket?? Oil pump?? Thx Jim |
01-18-2012, 07:51 AM
both oil pumps will work...
there are slight differences in the two headgaskets between 16V and 20V but nothing serious to worry about as far as I'm concerned - here's a comparison picture of the web (20V on top, 16V at bottom) ![]() AE86 ex-daily |
01-18-2012, 06:41 PM
I've always followed the belief... the gasket matches the head. The 20V uses a different coolant flow direction then the 16V does.
Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
01-18-2012, 08:20 PM
20V gasket it is!! Thx!!
What about all the pulleys? |
4age 16v 1st and 2nd generation cams and not only difference | Apsogos | 3 | 7,811 |
09-16-2013 08:24 AM Last Post: Apsogos |
4A-GE engine mix - question | Maren | 74 | 79,205 |
03-08-2012 01:01 PM Last Post: Uzelac |
