Rally Project
04-01-2011, 10:46 AM
Rally Project
That explains the lack of steering wheel.
I'll go stand in the corner now..dohh A wheel to steer the front of the car A pedal to steer the rear |
04-01-2011, 12:46 PM
Rally Project
Easy mistake.
Need to make s13 gravel rally coilovers now????? Not easy as there is not longstroke s13 coilovers available. thinking of getting celica gt4 ones & swapping the top-hat. An 86 is for Life, not just for Christmas |
04-01-2011, 01:19 PM
Rally Project
For rallying, my dumb opinion, would be to stick to things that are known to work and easy to replace. That might be the case with stock GT4 celica stuff. I don't know enough about them to make an educated guess.
A couple of setups have been proven time and time again. Best known example is the Escort MK2 GP4. Eerily similar to the AE86. In the front they run simple linear valved bilsteins that come in 3 valvings and two lengths. Gravel, Forest en Asfalt or something along those lines. They are rallied in huge numbers and front running cars often compete with WRC stuff on the same 90gbp bilstein dampers. They'll drop right into a AE86 strut housing if you drill the bottom of the strut for the retaining nut. That would be my approach with stock length AE86 struts. Steal your spring rates from the Escorts too. The dampers will be valved for them (huge advantage) and you get to use decades of competition experience. 5kg might be a tad too much. Corner weight/motion ratio's etc. are all extremely close, so thing are comparable Rear escort shock will drop right in. Come to think of it, a lot of rally 86 in the UK and Eire run Escort stuff, complete with the struts and the Atlas rear axle. Simple, cheap and proven. IMHO too big of an advantage to start mucking about and experimenting. A wheel to steer the front of the car A pedal to steer the rear |
04-01-2011, 01:28 PM
Rally Project
I already have bilsteins for the rear ae86 ones, I would go for normal rally spec bilstein insert coilovers but I have an s13 front set-up with wider track which I like & want to keep. Getting the ride height correct will be difficult.
How long is a stock ae86 front shock absorber, I wonder if im over thinking it. as in maybe s13 & ae86 front shocks are the same length & I just need a coilover kit. An 86 is for Life, not just for Christmas |
04-01-2011, 02:43 PM
Rally Project
From the NoHachi database:
Stock AE86 front Extended length: 604mm Body length: 402mm Stroke: 202mm OD: 44mm A wheel to steer the front of the car A pedal to steer the rear |
04-01-2011, 02:48 PM
Rally Project
S13 bilstein:
Extended length:533mm Body length: 330mm Closed length: 370mm Stroke: 172mm OD: 46mm Escort Mk2 long bilsteins (forest) Extended length:555mm Body length: 320mm Closed length: 488mm Stroke: 147mm OD: 46mm Measurements collect from the net and some by yours truly. As we say in Holland, you get a guarantee that lasts until the front door. A wheel to steer the front of the car A pedal to steer the rear |
04-01-2011, 03:41 PM
Rally Project
wow, what... Bilstein do a long stroke s13??????????????
05-29-2011, 06:50 AM
Rally Project
![]() ![]() ![]() ![]() Not all people will like the rims, but I dont care, solid magnesium ex-TTE Rally Australia st165 rims ![]() An 86 is for Life, not just for Christmas |
06-02-2011, 12:50 AM
Rally Project
Nice find.. Dude I know has several of the original TTE celica's in his garage. Very cool cars!
03-17-2012, 01:15 PM
Rally Project
Pissed off the s13 front as it was hopeless.
![]() ![]() An 86 is for Life, not just for Christmas |
nzae86's AE86 Levin Tarmac rally car build Project 1 | nzae86 | 30 | 57,099 |
04-30-2013 07:28 AM Last Post: nzae86 |
Spanish Tarmac Rally Project | leckter | 68 | 86,736 |
03-10-2012 03:51 PM Last Post: ZaX |
My ongoing AE86 road/rally/project car | zzgasoven | 1 | 5,154 |
03-18-2005 02:13 AM Last Post: zzgasoven |
