Rear Caliper Rebuild
09-22-2016, 10:37 AM
Hi Guys,
I am going for the RX7 FD calipers for the front of my build and the standard AE86 calipers on the rear.
The RX7s came with a Mazda rebuild kit but I'm not sure Toyota would supply such a kit anymore!
Can anyone recommend OR KNOW where I can find a pair of rebuild kits that are good quality?
Many Thanks,
Matt
09-22-2016, 10:43 AM
For the RX7? Smile
09-22-2016, 02:18 PM
Last time I checked the rebuild kits are still available. I'm out and about right now so can't check the part numbers
09-22-2016, 02:23 PM
(09-22-2016 10:43 AM)pack Wrote:  For the RX7? Smile
No no, already bought them with a kit so I'm sorted there Smile
(09-22-2016 02:18 PM)Bean Wrote:  Last time I checked the rebuild kits are still available. I'm out and about right now so can't check the part numbers
Cheers Bean! I wouldn't have thought they would still produce it, I'll do some digging Smile
09-22-2016, 03:32 PM
For the rear calipers... Theres plenty of kits available! Smile
09-22-2016, 03:54 PM (This post was last modified: 09-22-2016 03:59 PM by FanIsHere.)
Rear calipers' repair kits are available by Toyota at around €40.
Here's the part number: 04479-12110
[Image: AEU86 AE86 - Rear Caliper Rebuild]
Follow: The story of my AE86
09-23-2016, 11:08 AM
(09-22-2016 03:54 PM)FanIsHere Wrote:  Rear calipers' repair kits are available by Toyota at around €40.
PERFECT! Arigato ^_^
You wouldn't happen to have the part number for the L/R handbrake cables while we are here do you? Wink
09-23-2016, 11:38 AM
Top tip !
Use only the rubber grease supplied in the kit !
Matt, are you going to do the handbrake mechanism too ?
If you are and you are in the U.K I could send you the special nut required to hold down a spring in the caliper. It is actually part of an old brake piston so you could make one yourself if you have an old AE86 rear caliper piston.
09-23-2016, 12:14 PM
(09-23-2016 11:38 AM)totta Crolla Wrote:  Top tip !
What do you mean about the handbrake mech? I'll be replacing the cables etc Smile
I will either be sending them away to be done and high temp powdercoated or MIGHT tackle it myself. Just wanting it to be as near as new mechanicals as I can!
I am indeed in the UK, anything that would help would be appreciated!
09-23-2016, 01:10 PM
Flo's IE do sell the handbrake cables very cheap.....
Maybe you could check them!
I made a special nut for taht specific spring myself in PVC Wink hahaha Troublemsome spring by the way
  Bluetop Engine Rebuild multiple question Goal 150-160hp Hanzo 16 10,333 04-19-2021 10:08 PM
Last Post: Hanzo
  Rear Differential rebuild chenfon 10 10,119 11-20-2020 12:18 AM
Last Post: totta Crolla
  AE86 4A-GE 16v engine harness rebuild FanIsHere 7 10,710 01-17-2020 08:04 PM
Last Post: Project D
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 3,927 12-21-2016 09:37 PM
Last Post: bozu
  How would/have you rebuild your 4age? joaotcgt 6 9,240 07-21-2015 10:40 AM
