Rear Caliper Rebuild
09-22-2016, 10:37 AM
Hi Guys,
I am going for the RX7 FD calipers for the front of my build and the standard AE86 calipers on the rear. The RX7s came with a Mazda rebuild kit but I'm not sure Toyota would supply such a kit anymore! Can anyone recommend OR KNOW where I can find a pair of rebuild kits that are good quality? Many Thanks, Matt |
09-22-2016, 10:43 AM
For the RX7?
09-22-2016, 02:18 PM
Last time I checked the rebuild kits are still available. I'm out and about right now so can't check the part numbers
AE86 ex-daily |
09-22-2016, 02:23 PM
(09-22-2016 10:43 AM)pack Wrote: For the RX7? No no, already bought them with a kit so I'm sorted there ![]() (09-22-2016 02:18 PM)Bean Wrote: Last time I checked the rebuild kits are still available. I'm out and about right now so can't check the part numbers Cheers Bean! I wouldn't have thought they would still produce it, I'll do some digging ![]() |
09-22-2016, 03:32 PM
For the rear calipers... Theres plenty of kits available!
09-22-2016, 03:54 PM
(This post was last modified: 09-22-2016 03:59 PM by FanIsHere.)
Rear calipers' repair kits are available by Toyota at around €40.
Here's the part number: 04479-12110 ![]() ![]() Follow: The story of my AE86 |
09-23-2016, 11:08 AM
Rear Caliper Rebuild | |||
09-23-2016, 11:38 AM
Top tip !
Use only the rubber grease supplied in the kit ! Matt, are you going to do the handbrake mechanism too ? If you are and you are in the U.K I could send you the special nut required to hold down a spring in the caliper. It is actually part of an old brake piston so you could make one yourself if you have an old AE86 rear caliper piston. An analogue brain in a digital World |
09-23-2016, 12:14 PM
(09-23-2016 11:38 AM)totta Crolla Wrote: Top tip ! What do you mean about the handbrake mech? I'll be replacing the cables etc ![]() I will either be sending them away to be done and high temp powdercoated or MIGHT tackle it myself. Just wanting it to be as near as new mechanicals as I can! I am indeed in the UK, anything that would help would be appreciated! |
09-23-2016, 01:10 PM
Flo's IE do sell the handbrake cables very cheap.....
Maybe you could check them! I made a special nut for taht specific spring myself in PVC ![]() |
Bluetop Engine Rebuild multiple question Goal 150-160hp | Hanzo | 16 | 10,341 |
Rear Differential rebuild | chenfon | 10 | 10,125 |
AE86 4A-GE 16v engine harness rebuild | FanIsHere | 7 | 10,713 |
Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 3,927 |
How would/have you rebuild your 4age? | joaotcgt | 6 | 9,240 |
07-21-2015 10:40 AM Last Post: mad.matt |
