Rear Lights warning light ?
10-23-2005, 12:21 PM
Hi guys,
I did a bit of exploration work yesterday to try and figure out why my car keeps blowing the main gauge fuse each time I go drifting. Once I'd removed the lower section of the dashboard I was presented with a whole lot of wiring that isn't standard. The wiring loom had been modified a little to accomodate the stereo harness. There is also some wiring present to run the remote central locking system which I believe is not a standard thing on any corolla - the control box is near where the turn signal flasher unit and stuff is - and the ball of wires is pretty messy with lots of fuse breakouts and stuff. I insulated some bare ended wires in case this was causing my instrument panel short. As my car is so noisy inside it seemed hardly worth leaving a japanese cd/radio that hasnt been frequency converted in the car. I removed the stereo, speakers and all associated wiring. One other intermittent light that comes on on the dashboard is a light that says 'rear lights'. its on the right hand side of the dashboard under the main head lamp light. Does anyone know what this light means ? I've taken a quick look through the workshop manual in the BE section and I cant find anything on it ? All my rear lights are lit so I dont know why it would be on. One of the rear number plate lights is slightly dim - I wonder if this could be on its way out and causing the light to stay on ? Regards Ian. |
10-23-2005, 12:27 PM
I've never heard of this light before...might be JDM exclusive. Post up a pic if you have the opportunity to make one.
You followed the correct approach to the wiring by the way, I've seen some messy jobs myself in the past few years, I usually just rip out everything that looks wrong and start over again. FABRICA MI DIEM, PVNC! |
10-23-2005, 01:27 PM
Can you take a picture of it? I think that will clearify a lot.
High-beam warning lamp | Mylesmck | 4 | 1,534 |
07-21-2023 07:44 AM Last Post: banpei |
Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 8,156 |
12-19-2021 11:58 PM Last Post: gh0st |
Electrical - Rear Screen Demist and Dash lights | mad.matt | 0 | 3,727 |
01-12-2015 01:15 PM Last Post: mad.matt |
AVO Suspension from MCN Motorsport warning | 4000GT | 1 | 3,827 |
07-19-2013 04:48 AM Last Post: 4000GT |
Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 5,955 |
