Rear axle/diff has gone...
09-04-2012, 02:52 PM
On the latest track day, the rear started to sound more and more whining and grinding.
And on the way home it was sounding like a jet-plane. A terrible grinding noice. The diff was full with oil but what came out was not a pretty sight, a grey thick fluid with metall in it.
So the question is, what do I do now?
Open it up or just buy a new (used?) rear axle? Im not that mechanic to open up and look and fix the bearings and things.
What is the price of a used one in Europe?
Regards
Håkan
AE86 SWEDEN
https://www.facebook.com/ae86sweden
09-04-2012, 03:16 PM
Open it: it cost nothing to take a look and see what's dead inside Wink
09-04-2012, 03:37 PM
Project D Wrote:Open it: it cost nothing to take a look and see what's dead inside Wink
Yes, I have the workshop here at work so no problem with time, lifts and all thinkable tools and if its a bearing or two no problem and finding it, but knowledge... Wink
I tried to open it but I couldn get it off (the plate in front of diff) after disconnecting the propeller shaft.
http://www.toyodiy.com/parts/p_J_1986_TO..._4101.html
I losened all the nuts in the diff but it would come of, like something is holding it from inside. Do I have to remove the rear axles first before I can remove the diff?
AE86 SWEDEN
09-04-2012, 05:01 PM
Yes you have to remove the halfshafts (drivaxlar) first then the diff house should just come right out. Knowledge isn't a problem if you use the service manual Thumbs up!
09-04-2012, 05:26 PM
krullibull Wrote:Yes you have to remove the halfshafts (drivaxlar) first then the diff house should just come right out. Knowledge isn't a problem if you use the service manual Thumbs up!
Thanks. Smile
The Service Manual (AE86Manual.pdf) doesnt tell me to remove the driveaxles before the diff, what I can see. It only shows a picture of the parts of the diff. ( Page RA-8 ). Wink
EDIT: My bad I see now.
2. REMOVE REAR AXLE SHAFT ( See page RA-3 )
Big Grin
AE86 SWEDEN
09-09-2012, 01:15 PM
Any progress on this?
09-10-2012, 04:46 PM
I didnt have time this weekend but hope to take it apart this coming weekend.
I hope its not that hard to remove the axels (?) so I can remove the pinion and diff.
I feel (and hope) that it is the bearings (front and/or rear) for the pinion that has broken making the pinion go off line...
AE86 SWEDEN
09-10-2012, 06:10 PM
Skyracer Wrote:I didnt have time this weekend but hope to take it apart this coming weekend.
Chances are pretty slim for that m8...its usually the r&p that gives up...
09-10-2012, 06:53 PM
Removing axles isn't so difficult. I did it and was surprised how well it went. :wink: .
ハチロク
[Image: AEU86 AE86 - Rear axle/diff has gone...]
09-10-2012, 08:29 PM
Unless its the first time in yonks that you take them out, then it can be a bitch of a job. Make sure you have a slide hammer or something improvised that resembles one when you take on this job. If they have been out recently you can often take them out with a few gentle taps of a rubber mallet (or just by hand), but if they are rotted in there it will be much much harder (the bearings are 3+ cm's wide, that's a lot of surface).
  AE86 rear axle weight megabob 11 19,672 03-29-2024 11:18 AM
Last Post: FanIsHere
  Axle width totta Crolla 1 1,312 10-24-2023 12:20 PM
  Exhaust has white smoke coming out and I dont know why... mister86 3 4,869 01-19-2020 12:06 AM
Last Post: Power_uP
  Rear axle options Dino86 13 13,673 01-08-2018 10:19 PM
Last Post: ditn
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 3,927 12-21-2016 09:37 PM
Last Post: bozu
