Rear brake discs diameter?
08-21-2006, 09:48 PM
Hello Wave
I tried to search an information about ae86 rear brake discs diameter, but i haven't found it Confused
I measured front brake discs diameter today (it was about 243mm), but the weather became bad and it started to rain, so I couldn't measure rear discs diameter. Maybe some of you will help me and say what is the rear brake discs diameter? :wink:
White ae86 Levin
08-21-2006, 10:02 PM
These are the discs I ordered a year ago:
http://www.autopartsonline.nl/nl/ao_list...&art=27124
Quick translation:
Diameter 231.0
Massive/ventilated Solid
Diam. Upper part 159.0
Diam. hub 60.0
Thickness 10.0
Min. Thickness 9.0
Qty. holes other 2
Qty. wheelnut holes 4
Total Heigth 47.0
[Image: AEU86 AE86 - Rear brake discs diameter?]
08-21-2006, 10:11 PM
Thanks banpei :wink:
I saw rear discs with 231mm diameter in catalogue, and i will order it tomorrow! Smile
White ae86 Levin
08-21-2006, 11:33 PM
cool, that's very interesting!
will have to do same to mine, cause it also needs em!
talk to you on skype Nookie!
adam
  Handbrake adjustment discs? DMC 8 4,602 03-10-2024 08:08 PM
Last Post: DMC
  AE86 Rear Brake options. hachirokuGTV 66 142,938 08-27-2016 11:01 PM
Last Post: izanagi
  Piston Diameter Alex170984 11 18,391 02-07-2013 12:52 AM
Last Post: fax0815
  Rear ae86 rear discs & pad part numbers? J-86 4 7,595 11-30-2012 06:32 PM
Last Post: J-86
  Brake master cylinder for FC3S brake conversion Hachi Go 8 17,042 03-03-2011 12:06 AM
Last Post: filh
