Refurbish black plastic - how?
03-03-2012, 06:42 PM
I just recived my 86 from the paintshop Smile Nice fresh Super White II color. But all the black plastic, frontgrill, rear lights (whitelines) windowtrim ect. looks like shit on the new fresh paint Confused
Can I refurbish the plastic or are the only option, paint or buy new ones? I really really not want to paint it glossy black.
Project AE86 now begun.
Cars I have owned:
Toyota Starlet EP91 1,3 16v Turbo, 200hp
Toyota Starlet EP71 1,3 12v Sport
Mercedes 207D camper, 1977.
Toyota Starlet EP70 with a 174hp Silvertop 20v See video here:
http://videos.streetfire.net/search/Star...079edc.htm
Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint).
Volvo 240 2,1 (The only car I have maked money on).
Toyota Corolla EE90 (my first car)
03-03-2012, 06:46 PM
there are loads of plastic conditioners on the market, just buy one and try!
old engine oil does a good job, too Evil
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
03-03-2012, 06:50 PM
I don't think oil or any other spary-on products will do the trick. It's hard plastic and its like it been matt in the sun. I though about a polish or something like that.
Cars I have owned:
03-05-2012, 10:40 AM
Light sanding and matte black spray is also an option.
[Image: AEU86 AE86 - Refurbish black plastic - how?] http://www.jdmbits.com
03-05-2012, 12:50 PM
nmwisima Wrote:Light sanding and matte black spray is also an option.
X2
03-05-2012, 07:26 PM
I've seen cooked lineseed oil used to great effect for this exact purpose. You could try it out on some small bit and see if it works for you.
03-06-2012, 06:55 PM
You could try heating it gently with a "heat gun". If that doesn't work I know for a fact that there is a blueish sticky goo that you rub on the plastic to make it like new. I just can't remember the name of if right now.
03-06-2012, 08:52 PM
Thanks. I will try to polish it with 3M Extra Fine compound. It works on plastic headlamps.
If this dosn't works, I will try to heat it, or a last solution must be paint it matt black.
Cars I have owned:
03-07-2012, 12:05 AM
3M cutting compound is awesome but make sure you wet the mop a lot. Its a patience job but from what i´ve seen in the projects your car diserves it.
better result laquer spay the plastic after to make it a bit more shiny
03-08-2012, 10:48 PM
JonnyAE86 Wrote:3M cutting compound is awesome but make sure you wet the mop a lot. Its a patience job but from what i´ve seen in the projects your car diserves it.
Thanks man Smile
Cars I have owned:
  STL file for the early spec Levin headlight ball joint plastic clip DaLanZhu 2 2,665 04-26-2025 03:24 PM
Last Post: DaLanZhu
  plastic fuel tank bakonick 12 17,448 12-26-2012 12:08 AM
Last Post: bakonick
  T50 - Gearstick plastic bush? byd1380 7 10,430 01-31-2012 03:59 PM
Last Post: byd1380
  I need some info about the plastic under the 2 front fender Mattolo 4 7,656 02-22-2010 01:28 PM
Last Post: Mattolo
  Plastic restorer Rasteirinho 13 15,350 04-17-2006 02:48 PM
Last Post: Rasteirinho
