Reinforcement for the AE86...
05-12-2005, 11:02 AM
Go under the car and look around the gear box and driveshaft tunnel - you can add 1-2 braces nere (under the driveshaft) to reinforce the tunnel area near the gear box.
Another option is to fill all cavities with PU foam (but choose the foam carefully - the heavy and more densier will work better).
05-12-2005, 11:26 AM
Pics
Broken down 1984 Trueno HB
[Image: AEU86 AE86 - Reinforcement for the AE86...]
05-12-2005, 11:28 AM
more
05-12-2005, 11:30 AM
and more
05-12-2005, 01:00 PM
Most of the interior bars can be implemented in a roll cage....you just have to keep that in mind while designing your cage.
05-20-2005, 12:51 PM
jamiemirror Wrote:Go under the car and look around the gear box and driveshaft tunnel - you can add 1-2 braces nere (under the driveshaft) to reinforce the tunnel area near the gear box.
05-20-2005, 05:20 PM
well it looks like you can add braces everywhere, put that lot on and get a 2000kg car. I wonder how many actually do anything worthwhile and arn't just for show ?
05-20-2005, 06:38 PM
Jon you are kinda right, and kinda wrong.
If u use aluminum or carbon to make all these,
the car won't be much heavier.
But why bother to use all these shit,
since u can just use a cage and one tri-bar front
and one in tri-bar in the back?
[Image: AEU86 AE86 - Reinforcement for the AE86...] http://www.jdmbits.com
05-21-2005, 02:38 AM
well if you want to keep the interiour, you can implememt the bars in there, but with a cage you have to strip it.....
05-21-2005, 09:50 PM
I also think a lot of these braces are bullshit, but some do have their purpose. The panhard rod reinfcement looks like it might be a good thing to reduce stress and flex, but only for a drifting car. Most of the rear strut towers probably do very little to improve stiffness (especially in coupe's). There is only a lot of stress on those points when you use coilovers in the rear.
  Rollcage and chasis reinforcement gangstarr 9 10,167 05-11-2006 09:10 PM
Last Post: SekiguchiUeno
User(s) browsing this thread:
