Replacing of the bushings
11-22-2004, 01:17 AM
Guys, i'm still waiting for report of instaling the group buy bushings.
Not that much about the impresions of handling, because i know it will be a big improvement, but on how did you change the bushings.
Especially on rear four trailing arms.
I have a big problem with removing stuck bolt inside the bushing.
[Image: AEU86 AE86 - Replacing of the bushings]
I tried lot's of aproaches, but non of them worked except the angle grinder + cuting the bolt head.
Please post some of your ideas.
11-22-2004, 01:24 AM
2m metal tube
11-22-2004, 01:30 AM
Aico Wrote:2m metal tube
um, not working, since bolt is rotating inside the trailing arm housing.
whole bushing is rotating when you unscrew the bolt, but there is no force apllying on the bolt, so you are not pushing it out.
We tried today to weld the nut on the other side of the rear side of the bolt, but the weld broke of, but bolt did not go out.
11-22-2004, 01:44 AM
just warm it with a heatgun ???
11-22-2004, 11:06 AM
i had to use the flex (grinder) too Sad
11-22-2004, 11:33 AM
@Zax,
Everthing on my car did come lose very easy, gues I was extreem lucky if you consider the age of the car. Maybe the flexgrinder is a option, than you only have put on a new bold and nut.
Michel
Daily driver: Seat Leon Cupra V6
Summercar: E30 M3 Cecotto
Projectcar: AE86
11-22-2004, 11:37 AM
When I took my spare axle appart it had all the arms attached (although the long ones where cut off half way). I got all the bolts out just fine except one. It has rusted to the metal insert inside the bushing so there is no way to get that loose except for cutting that bolt which I will do next time I have some time..
I hope I will be more lucky when I replace the axles...
11-22-2004, 01:35 PM
Most of the bolts on the hachi haven't been removed in 20 years most if it just has to be heatet up then it will release.
by the way zax you hachi looks good from below
11-22-2004, 01:43 PM
robokill Wrote:by the way zax you hachi looks good from below
I noticed that as well, how the hell did you get it to look that clean? Thumbs up!
11-22-2004, 02:24 PM
He took out the silver spray can and went nuts! Wink
I want my hachi to look as clean too!
  Replacing Top Windscreen Moulding chrisae86 2 2,164 06-18-2022 08:56 PM
Last Post: chrisae86
  Replacing front lca zenki 6 5,898 05-02-2017 03:23 PM
Last Post: pack
  Poly vs OEM bushings Jezza_hr 5 7,748 05-14-2014 11:28 PM
Last Post: Jezza_hr
  Replacing brake servo/booster Eifelaner 6 6,956 08-17-2013 11:19 PM
Last Post: Eifelaner
  Replacing window wipers bozu 6 7,626 04-11-2012 03:15 PM
Last Post: zenki
