Replacing brake servo/booster
08-16-2013, 01:15 PM
Im trying to replace my brakeservo,
i did what the book told me, but im stuck as you can see ![]() have i missed something? to me it looks like i have to take the intake manifold of :S i hope someone can give me a hint thanks eric |
08-16-2013, 06:11 PM
I'd sure try to jack/lift the engine up or pry it over before removing then manifold.
The mounts should give/stretch a cm or 2 if they're not broken and they should easily take 1cm without breaking, 2 is chancing it. |
08-16-2013, 10:46 PM
From memory I think you can unscrew the fork part that connects to the brake pedal and doing this will make enough room to remove the servo.
08-17-2013, 01:30 AM
i allready took of the fork thingy, the rod is still to long, thats ehy im stuck
08-17-2013, 02:17 PM
was a while ago...
maybe try to push the rod in ? An analogue brain in a digital World |
08-17-2013, 11:19 PM
i'll try that when i have a friend over to help me
| Brake booster braket | Mylesmck | 0 | 1,810 |
05-19-2023 12:56 PM Last Post: Mylesmck |
| Replacing Top Windscreen Moulding | chrisae86 | 2 | 3,276 |
06-18-2022 08:56 PM Last Post: chrisae86 |
| Replacing front lca | zenki | 6 | 7,332 |
05-02-2017 03:23 PM Last Post: pack |
| brake booster difference zenki(2 bolt)/kouki 4 bolt v | ditn | 1 | 5,352 |
03-22-2016 09:43 PM Last Post: ditn |
| AE92 brake booster and master cylinder into AE86 | bel_air | 8 | 14,156 |
08-02-2012 10:51 AM Last Post: bel_air |
![AEU86 AE86 - Replacing brake servo/booster [Image: AEU86 AE86 - Replacing brake servo/booster]](https://buqtaa.bn1.livefilestore.com/y2p6QIW8UoLCEv0K_GvQQE7estPBSHIY5588vhvOpPqVbDDqzVcgfjn0A92rVPtQjajh6J1vu4tMBcWq8-6_Bp5jvEG9ng4agW8eQhDoPG6z4c/WP_20130815_001.jpg?psid=1)
