Replacing brake servo/booster
08-16-2013, 01:15 PM
Im trying to replace my brakeservo,
i did what the book told me, but im stuck as you can see have i missed something? to me it looks like i have to take the intake manifold of :S i hope someone can give me a hint thanks eric |
08-16-2013, 06:11 PM
I'd sure try to jack/lift the engine up or pry it over before removing then manifold.
The mounts should give/stretch a cm or 2 if they're not broken and they should easily take 1cm without breaking, 2 is chancing it. |
08-16-2013, 10:46 PM
From memory I think you can unscrew the fork part that connects to the brake pedal and doing this will make enough room to remove the servo.
08-17-2013, 01:30 AM
i allready took of the fork thingy, the rod is still to long, thats ehy im stuck
08-17-2013, 02:17 PM
was a while ago...
maybe try to push the rod in ? An analogue brain in a digital World |
08-17-2013, 11:19 PM
i'll try that when i have a friend over to help me
Brake booster braket | Mylesmck | 0 | 891 |
05-19-2023 12:56 PM Last Post: Mylesmck |
Replacing Top Windscreen Moulding | chrisae86 | 2 | 1,964 |
Replacing front lca | zenki | 6 | 5,679 |
05-02-2017 03:23 PM Last Post: pack |
brake booster difference zenki(2 bolt)/kouki 4 bolt v | ditn | 1 | 4,288 |
03-22-2016 09:43 PM Last Post: ditn |
AE92 brake booster and master cylinder into AE86 | bel_air | 8 | 12,235 |
08-02-2012 10:51 AM Last Post: bel_air |
