Rev counter
11-09-2006, 06:43 PM
Rev counter
ok got the car starting, the engine was not cranking fast enough with the cold and heavier oil.
the ecu wont run the standard rev counter and i want it to work cos it looks better. the ecu guys said the output from ecu is 5v and the dash needs 12v. the fact that its on coil pack and not a dizzy isnt helping it either. same prob when swapping in a 4agze engine and i was wondering if anyone knew of some one who has the converters to make the old ae86 rev counter work with the signal from coil packs.
Its gotta go whoosh or give a whine!!!!
11-09-2006, 06:52 PM
Rev counter
Ehm.. lemme think about that one.. wouldnt you get in trouble anyway because one coilpack fires at half the speed of the regular coil?
11-10-2006, 01:59 AM
Rev counter
i dont know. do you think its possible to use the back of a rev counter that works on the signal and retro fit it to the back of the ae86 gauge so i can have the original looking gauge?
as far as im aware its not speed. the problem is cos is twin firing and the gaugh cant pick up the twin signal, i think.
oh and does the fwd 4age starter have better gearing to give a faster cranking speed?
also, when the car starts it is starved of revs for bout 1 min you need to give a slight bit of throttle. the idle screw is set correctly, any ideas on what it could be? it only from cold.
11-10-2006, 11:17 AM
Rev counter
http://picasso.org/mjlj/?q=node/606
Take a look at the bottom of this page.
Rev counter
Uhm, I never heard of a coil pack before but judging by your answers I think you mean there's actually two coils right...
In general it should always be possible to connect a rev counter directly to the connection between coil and ECU (or whatever else is controls the ignition, contact breakers or electronic ignition) ...
If I get it right you have two coils that are each doing half of the sparks... If so, I'd try taking two diodes and connect the tacho to both coils. So each diode goes with it's cathode side on the wires from a coil to the ECU and you connect both anode sides of the diodes together and take signal from there...
Ivan do you think I am anywhere near right here?
11-10-2006, 11:19 AM
Rev counter
jamiemirror Wrote:http://picasso.org/mjlj/?q=node/606
Ok, at least I was (almost) right... Only a bit to late :-)
11-10-2006, 11:37 AM
Rev counter
Not too late - you are a smart guy mate Big Grin
  Raising the rev limit on stock ECU fax0815 2 11,195 08-31-2015 02:04 PM
Last Post: gon
  4age 16v oem ecu rev limiter research ditn 18 29,175 06-22-2015 08:02 AM
Last Post: ditn
  High rev problem stratosTRD 6 9,918 07-03-2013 12:05 AM
Last Post: jondee86
  stand alone ECU but i want to keep my rev clock williep12 28 29,936 08-25-2010 02:26 PM
Last Post: thanhngo
  help 4age wont rev!?!? ep71 15 23,020 06-30-2010 10:27 PM
Last Post: jondee86
User(s) browsing this thread:
