Reving/Idle Problem???
11-17-2011, 09:13 PM
right i have recently rebuilt the head in my car ,
the car starts in a shot and idles perfect, but when i try to rev the car it splutters and missfires and is not responsive in any way? is the timing slightly out or do i have another problem? thanks in advance |
11-17-2011, 09:53 PM
jamieae86 Wrote:right i have recently rebuilt the head in my car , i think it's waaaaayyyy out :wink: AE86 FANATIC!!! |
11-17-2011, 10:11 PM
i have cylinder 1 at TDC , cams rocking on cylinder 4, and the rotor arm just before tip 1,
thats correct ? but there is also play in the throttle body could this be part of problem? also i have a set of 264/8.35mm lift cams are they safe to run on a standard head or shoud i get upreated springs? |
11-18-2011, 09:14 AM
Number 1 cylinder at TDC on compression stroke.
Crank timing pulley at zero degrees. Dimples on the rim of the cam pulleys lined with marks on backing plate. Knock pin on intake cam at 12 o'clock. Knock pin on exhaust cam at 5 o'clock. Bit of slop in the throttle plate spindle bearings... no big deal. Might make it difficult to hold a perfect idle. At 8.35 lift cams, you right in no-man's land. Some say it's safe, and others say no way. You are close to the limit, so I would say get some TRD or HKS springs. That way you know you are safe, and have new springs that will run an extra 1000 rpm or so above stock springs. There is no other problem in running those cams. Cheers... jondee86 |
11-18-2011, 01:29 PM
Check also ignition point after timing
11-19-2011, 01:52 AM
when i shake the throttle body pulley, it is very loose and moves the tps side, could a leak of air through here be a fault?
11-19-2011, 02:07 AM
Try another throttle body. Opening the throttle is a much bigger air leak
than you will ever get thru the spindle bearing, but the TPS could be forked internally. Did you take the cam pulleys off the cams when you worked on the head ? If you did... have you checked the position of the knock pins (those pegs in the end of the cam that go into the slots in the cam pulleys) ?? Cheers... jondee86 |
11-19-2011, 02:49 AM
I can gurantee the car will not run at all if the exhaust camgear ist set to the wrong pin, I tried very hard for 2 weeks.
11-20-2011, 02:12 PM
ok i will try the new throttle body and let ye know, thanks
11-24-2011, 08:03 PM
jamieae86 Wrote:ok i will try the new throttle body and let ye know, thanks When you remove throttle it's good to: 1) Replace 2 seals on the butterfly shaft to prevent false air coming in and reduce shaft vibrations. I think I manage to find 15/9 seals, the original is 15/10 (as far as I remember, better mesure it first) and it’s very hard to find. Put some grease during replacement. 2) Inspect throttle plate and shaft from wear and sharp edges (usually occurs on plate sides and cause "sticky" throttle feel). Carefully remove sharp edges (if there is any). Fun is not the straight line! |
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,506 |
Engine starts/revs but no idle | GenkiMotors | 17 | 7,519 |
11-20-2021 04:12 AM Last Post: GenkiMotors |
exhaust odor/idle MOT issue | Ryo | 7 | 7,341 |
20v silvertop idle issue | AlexFourTwenty | 3 | 5,203 |
12-24-2017 03:27 AM Last Post: AlexFourTwenty |
Silver top low idle | AlexFourTwenty | 7 | 10,246 |
10-16-2017 10:22 PM Last Post: AlexFourTwenty |
