Rich's AE86 projectu - 56K crashu
03-15-2007, 01:04 PM
Post: #41
SutteR,
If I see correctly these are rails that allow you to move the seat forward/backwards. Price is not cheap but I wouldn't say its expensive either for a low volume product that looks like its good quality. Quality control on such products most likely push the price up aswell.
Also, similar products often run up to similar prices. Just check for Sparco or Ricardo adjustable seat rails they aint cheap either.
Honestly, if you value your health in an accident situation, I would never trust home made adjustable seat rails. In such case you probably already bought a good quality bucket that costs you 500E and up, so a seat rail like this..
Offcourse if you're just going for looks and aren't planning to go out to the tracks, a 150E bucket and some universal non adjustable brackets or home made brackets for 25E do just fine.
03-15-2007, 01:23 PM
Post: #42
bastian - my thoughts exactly - I'd rather spend less on fancy bits so \i can afford high quality cage/seats/harnesses/rails etc
Besides i sold the nasty gay wing for £100 so technically the rails cost me a tenner Cool
[Image: AEU86 AE86 - Rich's AE86 projectu - 56K crashu][Image: AEU86 AE86 - Rich's AE86 projectu - 56K crashu]
03-15-2007, 09:40 PM
Post: #43
Guys, you don't live in Hungary...
The adjustable rail part can be made of OEM hachi rails simply cutting down the unnecessary part holding the original backrest of the seat. The sparco corbeau omp or any else rails can be attached to this. Not so complicated though I'm not the right person to fabricate it myself. Smile
1987 Toyota Corolla GT coupe - for holidays oversteer
2005 Toyota Corolla - for daily understeer
03-28-2007, 11:41 PM
Post: #44
SutteR - someone just told me of this modification - I will see him on Saturday to look at it
Mini-Update:
UPDATE:
New rocker covers as I managed to crack one Blush
Painted by me in UHT satin rattle can and detailed with her indoors's most expensive sparkly silver nail varnish Huh
Does anyone know where this connector should be connected to? Found it swinging around in fresh air between the first injector as you look at the block and the tvis unit - engine is apparently from an ae92 if that helps?
Trying to decide on 20v ITB's and a VEMS or a full engine/completely different motor....
03-29-2007, 07:37 AM
Post: #45
For me it seems to be a connector to one of the injectors but if your engine is running right then I'm wrong.
03-29-2007, 11:27 AM
Post: #46
That connector goes under the intake manifold to the tvis opening device.
Best regards
03-29-2007, 12:06 PM
Post: #47
Looks like the conector of cold start injector in the intake manifold.
Cump´s
Filipe Oliveira
03-29-2007, 12:54 PM
Post: #48
Lipinhu Wrote:Looks like the conector of cold start injector in the intake manifold.
The cold start injectior seems to be connected - you can see it on the upper pics.
03-29-2007, 01:44 PM
Post: #49
That connector goes under the intake manifold to the tvis opening device, I'm sure.
03-29-2007, 04:30 PM
Post: #50
apardal, is right:-D its for the tvis
  @dodo@ Levin Coupe, renovation and tuning (56k think twice) @dodo@ 165 161,718 03-28-2018 12:35 PM
  Ive been busy.. F20C AE86 (56k badness!) PazzaAE86 46 90,273 06-25-2011 04:49 PM
Last Post: kennedy8383
  Project: My new trackday toy (56k beware!) Morten 88 81,976 02-25-2010 01:44 PM
Last Post: Morten
  electric's double grey JDM Trueno (56k warning) electric mic 17 19,160 12-21-2007 02:45 PM
Last Post: domi
  Peter's Lambo Trueno 56K NO WAY! tomstwincam 12 14,752 02-03-2007 05:40 PM
Last Post: TRUENO><ONEURT
