Richieu -Technical help desk
09-20-2005, 08:19 AM
Ive just stripped down my drivers side door. Theres a slight dent in the door and some one had put filler over top to hid it then they painted over it with anti rust paint. However they did a bad job and the paint cracked. So thats why I stripped it. Once there was metal showing where the filler was I used Rust Netuliser which is meant to netulise the rust the I used Rust Convertor over that. Now I will use body filler to smooth over and then primer it then paint. Is this a correct once of protecting it from getting rusted in future.
Cheers I once read that you shouldnt believe everything you read. |
Messages In This Thread |
Richieu -Technical help desk - richieu - 09-17-2005, 10:15 AM
[] - James - 09-20-2005 08:19 AM
$age Engine And Gearbox Problem... HELP - crucifycry - 08-24-2008, 04:35 PM
how can you close a sunroof manually - 3stoyo - 10-04-2008, 04:47 AM
[] - NightAddict - 08-31-2011, 10:32 PM
Tomei 16V poncams + Tomei technical trax 1.5 way LSD | Lt86 | 22 | 20,291 |
09-16-2016 09:56 PM Last Post: Alex170984 |
technical asking about TVIS | filh | 4 | 6,194 |
02-27-2011 02:07 AM Last Post: filh |
www.aeu86.org Technical FAQ | Mux213 | 0 | 11,071 |
12-20-2005 06:45 PM Last Post: Mux213 |
