Robokill's Panda Levin Coupe!
10-15-2007, 11:34 AM
Post: #191
Hehe... That's a bit higher than you expected.
10-15-2007, 02:30 PM
Post: #192
Yup very good result for a sucky 16v :wink:
I'm sure there's a bit more power when you get the mixture right.. |
10-16-2007, 10:46 AM
Post: #193
Here is the dyno graph. Now I gotte get myselve some 250+ injectors and then mount the ITB. I wonder what the power output then be.
10-16-2007, 01:04 PM
Post: #194
Hey Lennert..looks good man, nice torque curve..you could probably tune out those few bumps you have with a decent ECU. Could you do a couple of 0-100km/h tests? Do them in several directions etc and take the average of the readings..
10-16-2007, 01:15 PM
Post: #195
? 0-100 ? you mean how many secs? sure could try have to set it up caus then i need someone with a timer.
Don't think they'll be very high as the torgue is still pretty low on the engine. I was thinking of going ITB and megasquirt and then fine tune the last bit. Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
10-16-2007, 03:39 PM
Post: #196
Looks good...that is wheel HP right? So that would be around 170-180 engine HP, I want that much power too
Lennert could you post the engine specs? |
10-16-2007, 03:53 PM
Post: #197
i am guessing between 140-160 crank hp its always a gamble:
7 rib lower block (no squirters) 81.5 toyota pistons (18mm pin) 40 mm crankshaft worked head (ported and flowed) standard toyota headgasket Standard injectors CATCAMS 7105137 260 / 252° 9.00 / 8.50mm nokassen standard header with custom 2-1 downpipe and single 5.5cm downpipe to the back of the car. Open air filter. That about it.. with difrent intake (itb) difrent injectors and a megasquirt I am aiming for 140 whp. Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
10-16-2007, 05:01 PM
Post: #198
Your torque is absolutely fine for this HP level..more then a stock 4A-GE and straight. So time to see some practical performance figures..also maybe some 80-120km/h tests. They will give you a nice indication of further improvements.
10-16-2007, 05:18 PM
Post: #199
Robo you can buy my Blacktop. Then you have 143whp. "Stock" motor too hehe. :wink:
Nah I hope you'll get it sorted, I guess it shows that the 16v is still a nice engine to play with. You've already left some 20v's behind so that's a good thing. Looking at your torque-curve..that really looks very good. Mine is similiar but because of the 75mm itb's, torque is a bit low. Stock it was 133whp, about the same the other 20v's had last weekend, and then after 2,5" catback and the ITB's I gained a nice 12whp. Now I had 143whp but that's probably due to 1" bigger wheels and obviously the usual tear&wear I guess. So yeah, some nice ITB's and a good tune could give you quite a few extra pony's ! |
10-17-2007, 02:11 PM
Post: #200
robokill Wrote:i am guessing between 140-160 crank hp its always a gamble:Yes around 150 crank hp would properly be a good guess.. that's very good fore a bigport head and intake with those cams What compression ratio do the engine have? |
Banpei's two door panda Trueno from Japan | banpei | 6 | 513 |
01-06-2025 08:31 PM Last Post: Eircamae86 |
Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 15,212 |
@dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 161,584 |
Aram's 3SGE Beams Levin Coupe | robokill | 665 | 741,589 |
Matt's "Drives as fast as it's Towed" 85 Levin Coupe | mad.matt | 38 | 40,376 |
04-07-2016 12:15 PM Last Post: mad.matt |
User(s) browsing this thread: 34 Guest(s)
