Rod-crank bearings? where to buy?
09-29-2005, 04:45 PM
Hi im thinking of rebuilding just the bottom end, since it seems mj bearings have developed a little space and pinging sound can be heard. i dunno if that could be because i used semi-synt 10w40 castrol TXT. Maybe the previous owner used mineral oils. Could that be it?
So where can i get rod bearings the cheapest? and also interested in sump-gasket?
tnx, saš
09-29-2005, 06:17 PM
Cheap ones are "TAIHO" (up to 40EU rod&crank).
AFAIK the Clevite 77 brand are very good ones too - another option is original Toyota (rumours that they are made by Clevite, but also rumours that they are TAIHO-made also). I bought sump gasket when I bought full gasket set ("RIKEN" brand, 35EU). If you buy the full gasket set - you can replace all old rubber gaskets at once - this is a smart investment I think. I rebuilt my Honda using "RIKEN" and 20 000kms later I'm yet satisfied.
i got mine directly from toyota
as these are genuine..!! better stuff..!!
as for the gasket just use worth sealer..!!
i was told that dukams 20w50 is best stuff til ave in the 4age..
09-29-2005, 07:17 PM
tnx, for the replys..
What is in that reiken full gasket set? also the head gasket? and how much is the whole set? where can i get this stuff?
i would also like to know where can i get Taiho or Clrvite bearings? links?
does anybody have a clue of how much a oem toyota bearings cost?
09-29-2005, 07:29 PM
I bought all stuff from local stores - so I cannot provide links.
Check http://www.google.com in your country for importers of Clevite and RIKEN - for example ? The "Clevite 77" is brand for reinforced "racing type" bearings.
Yes, the RIKEN set is full one - head, bottom end and exhaust gaskets (even the two "ring" ones of 4-2-1 design), valve stem rubbers. Very cheap - 35EU here. If I buy all these separate (the same brand) - I must pay ~2.5X more :-)
PS:The original Toyota head gasket is ~40EU here - for comparation.
09-29-2005, 08:26 PM
35eur for a whole set??! geez that IS cheap! thanx, i shall ask around..
just btw, i checked the fensport site and a complete gasket set comes some 150 eur or something like that.
tnx alot!
09-29-2005, 08:32 PM
Man, I even expected that this kit will not work. But now I have 20 000 km test in Honda small engine. This is a cheap way - I don't know is it robust enough for tuned 4AGE engine - time will tell (for me).
09-29-2005, 10:46 PM
I would recommend you to buy original toyota bearing.. The price is so low ( i gave 15E a piece for conrod bearings) that it would be stupid to buy aftermarket stuff that wont last anyways.
09-29-2005, 11:39 PM
well, i will see first how much can i get them for here. if they will be 15eur a piece.. than ill probably take them (is that 15eur the whole bearing or just one half? couse 60 eur isnt much more than 40, but 120 is 3x as much..
09-29-2005, 11:41 PM
The 15E was for a complete bearing... You have to consider the quality, not just the price. A cheap bearing that fails, will damage the crank...and you dont want that :wink:
  Question on Rod Bearings mister86 3 4,678 03-19-2020 03:46 AM
  Emergency help find store with bearings france Allexz 5 5,543 09-12-2019 03:24 PM
Last Post: Allexz
  AE86 4age engine not starts crank ok backfires to air intake Ryo 18 19,620 08-16-2018 01:36 AM
  crank 6 bolt flywheel DJexor 5 8,946 12-05-2016 08:21 AM
Last Post: d3nso
  4ac crank on 4age! Ghetto 7 11,044 12-05-2014 10:42 PM
Last Post: Uzelac
