Roll Cage
06-28-2009, 09:08 PM
Roll Cage
I have a similar question. Should i use 4 point harness without the cage? In case of a standard safety belt, if you roll and the roof gets squished, you have room for lateral movement, so you could be pushed aside.. but im afraid that woth 4 point, your body will be just fixed in upright position, and if the roof gets squished, your head gets squished..
06-28-2009, 09:13 PM
Roll Cage
Apolan Wrote:I have a similar question. Should i use 4 point harness without the cage? In case of a standard safety belt, if you roll and the roof gets squished, you have room for lateral movement, so you could be pushed aside.. but im afraid that woth 4 point, your body will be just fixed in upright position, and if the roof gets squished, your head gets squished.. Exactly Apolan. Someone please help us. |
06-28-2009, 10:04 PM
Roll Cage
That might be a problem... But they do also keep your body in your seat instead of flying through the car...But in 4 point harnesses and a frontal accident you get submarining. So 5-6 points would be better again...but less comfy..
Conclusion: roll over accidents are a serious hazard to your health. You really shouldn't be risking one by driving like a pillock on the street and on the track you are better of with a full cage etc. PS: a rear roll bar "might" be an option for a street car. As long as you can keep it a LONG way from your coconut. Not sure how all the popular ones are constructed. A wheel to steer the front of the car A pedal to steer the rear |
06-28-2009, 10:10 PM
Roll Cage
I'm gonna look up how to make a roll bar then as opposed to a full cage, I'm sure that would be easier.
Thank you nohachi |
06-28-2009, 10:49 PM
Roll Cage
This sort of hidden rolcage that Apolan mentioned is used by RUF to stiffen Porsche chassis and hide it under interior trim.
http://www.86ers.org All the hachies that Daytona can only dream about. |
06-29-2009, 12:35 AM
Roll Cage
Just like the Cusco ones right? The cusco ones cant even pass any regulations, they are just for rigidity. Dumb IMO. If I put in a cage, I want to not die with it in my car. |
06-29-2009, 12:50 AM
Roll Cage
NoHachi Wrote:That might be a problem... But they do also keep your body in your seat instead of flying through the car...But in 4 point harnesses and a frontal accident you get submarining. So 5-6 points would be better again...but less comfy.. One of the reasons i chose Rallye 3 ASM for daily use,comfy enough,cheap and ASM. http://www.youtube.com/watch?v=HR_FhuSEa...re=related |
06-29-2009, 01:00 AM
Roll Cage
Thanks a112!
This is a great thread, you all are helping me so much. |
06-29-2009, 08:45 AM
Roll Cage
Lofty Wrote:^^^ Not quite like cusco.. Cusco has eyelet style swivel connections troughout the cage. None of the tubes are connected by rigid joints. So you don't gain as much rigidity as you could have. Cusco cages might make the car a little bit safer. Depends on if they hold out during a crash. All the forces of the crash have to pass through those single bolts (at least they are all in double shear). From a purely physical standpoint, Cusco cages are about the worst that you can find. Lotsa bends in the main tubes, very narrow tubing and hinging connections. Maybe they work, maybe they don't, but they start out in life a little bit handicapped. I think its done to keep the cage cheap. No difficult fishmouth cutouts are needed and all the welding is limited to some weld on tabs. A wheel to steer the front of the car A pedal to steer the rear |
06-29-2009, 07:05 PM
Roll Cage
Matter bold on cages come with FIA...
Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
AE86 roll center adjusters for Carina | nyberrg | 9 | 12,367 |
06-16-2015 02:45 AM Last Post: roman |
Roll centre adjusters | totta Crolla | 9 | 11,839 |
10-21-2013 06:05 PM Last Post: Deuce Cam |
why do you use "roll center ajuster"? | leckter | 15 | 18,240 |
02-07-2012 07:04 PM Last Post: Bean |
Front Anti Roll Bar for Beams Swap | KD2229 | 5 | 6,245 |
09-20-2011 10:04 AM Last Post: Aram |
TE71 roll cage | totta Crolla | 3 | 5,280 |
02-04-2011 05:43 PM Last Post: corolla4agze |
