Rough idle cutting out :(
02-14-2007, 02:03 PM
hi guys,
i know im new here but i hope you guys here can help me. here is my problem
first off, ive checked for fault codes, replaced plugs, it got a fuel filter at the end of the summer.
as im idling in traffic at 800-900rpm it'll be grand not a bother, then a big miss will come in, it will drop to 400rpm or so then regain right away, it might do tis 3 times, it might do it once, it might not do it at all. but its been doing it more than before. sometimes th miss is bad enough to stall the engine, then ive to restart it. it happened to me 4 times this morning on the wat to work. it was idling fine then a massive misfire and cut out. i started it right back up and it was perfect . please help Sad
oh and its a 4age big-port T-VIS MAP SENSOR standard exept for ehaust
02-14-2007, 02:54 PM
check the TPS plug and screws and look for low-level coolant ...
02-14-2007, 02:58 PM
Hello MAX
I'm not really sure but i think it has something to do with your MAP sensor. Maybe it reads the wrong amount of air coming in perhaps dew to an air likage from a hole.
The other thing that i can imaging is a faulty pressure solenoid (i don't know if this is the wright word)
Undecided
  No idle below 2000 rpm rich running Steller Engineering 3 1,746 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Engine starts/revs but no idle GenkiMotors 17 8,241 11-20-2021 04:12 AM
Last Post: GenkiMotors
  exhaust odor/idle MOT issue Ryo 7 7,844 07-15-2019 09:17 AM
Last Post: jondee86
  20v silvertop idle issue AlexFourTwenty 3 5,416 12-24-2017 03:27 AM
Last Post: AlexFourTwenty
  Silver top low idle AlexFourTwenty 7 10,696 10-16-2017 10:22 PM
User(s) browsing this thread:
