S.K.s AE86 racecar
12-19-2006, 10:51 PM
Post: #51
S.K.s AE86 racecar
As you can see, I spotwelded it and next I´m going to grind the edges and then put some glass fibre putty on and grind again and again and again...untill it look´s OK to me Cool
12-19-2006, 10:54 PM
Post: #52
S.K.s AE86 racecar
hmm.. sounds a bit strange to fill that stuff up with fibreglass.. couldnt you use something as a countermold from the underneath and fill it up with lead (soldering)? The roof is subject to an amount of stress, I wouldnt want to depend on something rigid and brittle to fill up those holes.
12-19-2006, 11:04 PM
Post: #53
S.K.s AE86 racecar
'Vertinning' (dunno the english word for it, filling up with lead, like Ivan said) is a very good way, only no one does it anymore.
Everyone is relying on fille nowadays, i'd rather see lead used for this kinda things.
12-19-2006, 11:21 PM
Post: #54
S.K.s AE86 racecar
Lead is the best way to fix it, but it sucks on a roof, remember the heat Smile
http://s141.photobucket.com/albums/r69/larszylauv/
12-20-2006, 12:06 AM
Post: #55
S.K.s AE86 racecar
why bother closing the sunroof. Remove the meckanism and your done
12-20-2006, 09:48 AM
Post: #56
S.K.s AE86 racecar
I was also thinking about welding the sunroof hole shut but then discarded the idea because with my welding skills the whole roof would most probably end up all wavy. I gutted the sunroof completely and used only the plastic frame - I'll then cut a piece of thin aluminium sheeting into the same shape as the glass panel and use small screws (and Sikaflex) to mount it onto the frame. After painting the whole thing with the same colour as the rest of the roof, it shouldn't look that bad I hope.
12-21-2006, 08:21 AM
Post: #57
S.K.s AE86 racecar
If I had a sunroof on my hachi I'd use some 2-composite body-glue on it. The roof wouldnt go wavy and the glues these days are so good that I've seen a car that had a fender replaced with glue, it had been crashed and fender had torn on the metal part and not on the glued part, probaply because on the glued part theres two layers of metal..
Totally rebuilding an AE86...
http://www.fintoys.net
http://www.findori.net
http://www.koti.mbnet.fi/teemu-t
12-24-2006, 12:24 AM
Post: #58
S.K.s AE86 racecar
Anyway I do it on my way. Today I put first a epoxyprimer to inside of the roof and then a Kent´s Quick Seal and then my father painted a whole interior with RAL9010
[Image: AEU86 AE86 - S.K.s AE86 racecar]
12-24-2006, 06:03 AM
Post: #59
S.K.s AE86 racecar
http://www.toymods.net/forums/showthread...ng+sunroof
saw this couple days ago only remembered it tonight
01-06-2007, 11:51 PM
Post: #60
S.K.s AE86 racecar
I changed a new pistons, conrods, headgasket, flywheel, clutch and clutchplate and bolts, now I have to adjust some valves...
Engine has found own place...
Inside
Fuel cell box
Down under
  ae86 racecar with beams engine bakonick 148 162,919 04-23-2024 10:06 PM
Last Post: bakonick
  Racecar: TRD USA built ITA AE86 oldeskewltoy 38 42,259 07-22-2019 02:55 PM
Last Post: apardal
  Firehawk's N2 racecar project firehawk 163 189,156 03-15-2010 08:28 PM
Last Post: Kid Karola
  Jonny's Levin Racecar Jonny Rochester 9 11,967 01-03-2010 04:34 PM
Last Post: woper
  Another AE86 build up - Racecar Jan Pedersen 18 20,212 06-09-2008 03:34 PM
Last Post: Jan Pedersen
