S.K.s AE86 racecar
12-19-2006, 10:51 PM
Post: #51
S.K.s AE86 racecar
As you can see, I spotwelded it and next I´m going to grind the edges and then put some glass fibre putty on and grind again and again and again...untill it look´s OK to me
12-19-2006, 10:54 PM
Post: #52
S.K.s AE86 racecar
hmm.. sounds a bit strange to fill that stuff up with fibreglass.. couldnt you use something as a countermold from the underneath and fill it up with lead (soldering)? The roof is subject to an amount of stress, I wouldnt want to depend on something rigid and brittle to fill up those holes.
12-19-2006, 11:04 PM
Post: #53
S.K.s AE86 racecar
'Vertinning' (dunno the english word for it, filling up with lead, like Ivan said) is a very good way, only no one does it anymore.
Everyone is relying on fille nowadays, i'd rather see lead used for this kinda things. "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
12-19-2006, 11:21 PM
Post: #54
S.K.s AE86 racecar
Lead is the best way to fix it, but it sucks on a roof, remember the heat
![]() http://s141.photobucket.com/albums/r69/larszylauv/ |
12-20-2006, 12:06 AM
Post: #55
S.K.s AE86 racecar
why bother closing the sunroof. Remove the meckanism and your done
12-20-2006, 09:48 AM
Post: #56
S.K.s AE86 racecar
I was also thinking about welding the sunroof hole shut but then discarded the idea because with my welding skills the whole roof would most probably end up all wavy. I gutted the sunroof completely and used only the plastic frame - I'll then cut a piece of thin aluminium sheeting into the same shape as the glass panel and use small screws (and Sikaflex) to mount it onto the frame. After painting the whole thing with the same colour as the rest of the roof, it shouldn't look that bad I hope.
12-21-2006, 08:21 AM
Post: #57
S.K.s AE86 racecar
If I had a sunroof on my hachi I'd use some 2-composite body-glue on it. The roof wouldnt go wavy and the glues these days are so good that I've seen a car that had a fender replaced with glue, it had been crashed and fender had torn on the metal part and not on the glued part, probaply because on the glued part theres two layers of metal..
Totally rebuilding an AE86... http://www.fintoys.net http://www.findori.net http://www.koti.mbnet.fi/teemu-t |
12-24-2006, 12:24 AM
Post: #58
S.K.s AE86 racecar
Anyway I do it on my way. Today I put first a epoxyprimer to inside of the roof and then a Kent´s Quick Seal and then my father painted a whole interior with RAL9010
12-24-2006, 06:03 AM
Post: #59
S.K.s AE86 racecar
http://www.toymods.net/forums/showthread...ng+sunroof
saw this couple days ago only remembered it tonight ![]() |
01-06-2007, 11:51 PM
Post: #60
S.K.s AE86 racecar
I changed a new pistons, conrods, headgasket, flywheel, clutch and clutchplate and bolts, now I have to adjust some valves...
![]() ![]() Engine has found own place... ![]() ![]() Inside ![]() Fuel cell box ![]() ![]() ![]() ![]() Down under ![]() |
ae86 racecar with beams engine | bakonick | 148 | 166,830 |
Racecar: TRD USA built ITA AE86 | oldeskewltoy | 38 | 43,975 |
07-22-2019 02:55 PM Last Post: apardal |
Firehawk's N2 racecar project | firehawk | 163 | 194,095 |
03-15-2010 08:28 PM Last Post: Kid Karola |
Jonny's Levin Racecar | Jonny Rochester | 9 | 12,223 |
01-03-2010 04:34 PM Last Post: woper |
Another AE86 build up - Racecar | Jan Pedersen | 18 | 20,718 |
06-09-2008 03:34 PM Last Post: Jan Pedersen |
