S.K.s AE86 racecar
08-22-2007, 09:40 AM
Post: #141
S.K.s AE86 racecar
irishtwincam Wrote:Cool.
We only had one of those distributors and didnt want to take it apart.
How did you get the plastic under the rotor arm off?
Do you ahve more pictures or information about the sequence to disassemble the unit?
What other engines did they come on?
Very cool article!
I ahd the "Spark advance vs Vacuum" curve somewhere.
Oh wait, did you remove the vacuum advance mechanism?
It is very easy to dissabled, sorry no other pictures. Plastic, with little screwdriver.
Middle axle is from 4A, but I have to weld a another lowerpart on it (without that it wouldn´t work).
Upper rotor is also from 4A, but I grinded pins and hit them out, then I put rest of it on a lathe and take that lowerpart off. Then I turned it around, pull the pins down and soldered it together.
Body is from 2E (1.3 12V) carb. engine, because it fits better to cylinder head, but I had to lathed it a bit.
Electrical system is also from 2E
Yes, I dump vacuum advance mechanism, for me centrifugal governor gives enough advance on right time.
Those three single wires goes to revolution limiter, so don´t care of those.
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!"
""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff"
-Henri Toivonen 2.5.1986-
http://www.youtube.com/watch?v=OwgB4Xs4LVQ
09-07-2007, 10:03 PM
Post: #142
S.K.s AE86 racecar
Little update.
Last weekend I finished the right door and now it is painted. I have a dynotime on monday, so let's see if everything is ok.
09-16-2007, 06:18 PM
Post: #143
S.K.s AE86 racecar
Dynotime was OK, but that rallysprint didn´t... Crying
http://www.samzon.kuvat.fi/kuvat/laihian...jpg/medium
other pics from rallysprint:
http://www.samzon.kuvat.fi/kuvat/laihian+sprint+2007/
09-16-2007, 06:25 PM
Post: #144
S.K.s AE86 racecar
Auch! Crying
Are you going to fix her up again? Dumb question
And what happend? Huh
[Image: AEU86 AE86 - S.K.s AE86 racecar]
09-16-2007, 06:39 PM
Post: #145
S.K.s AE86 racecar
:-( many cars died there:-(
09-16-2007, 07:05 PM
Post: #146
S.K.s AE86 racecar
banpei Wrote:Auch! Crying
Yes, it is fixable...but need some work...
I came too fast on one curve...(just like that number 55, and same place), then it just start rolling...3 rounds...I will get videoclip from it someday.
E:
another pic: http://rallikuvat.1g.fi/2007/laihia/imag...hia_46.jpg
and other: http://www.rallikuvat.net/2007/laihia/index.php#
09-16-2007, 08:39 PM
Post: #147
S.K.s AE86 racecar
Sorry to see that... a lot of hard work down the drain Sad
09-16-2007, 09:24 PM
Post: #148
S.K.s AE86 racecar
Damn too bad man, is the roof still straight?
09-16-2007, 09:31 PM
Post: #149
S.K.s AE86 racecar
E-volve Wrote:Damn too bad man, is the roof still straight?
The roofs left corner had little damage, also left A-pillar, but sunroofs hole/plate is still unvisible Smile
09-16-2007, 10:24 PM
Post: #150
S.K.s AE86 racecar
Nasty corner! Huh
Looks like you pulled it off better than 55. Smile
  ae86 racecar with beams engine bakonick 148 162,429 04-23-2024 10:06 PM
Last Post: bakonick
  Racecar: TRD USA built ITA AE86 oldeskewltoy 38 42,178 07-22-2019 02:55 PM
Last Post: apardal
  Firehawk's N2 racecar project firehawk 163 189,092 03-15-2010 08:28 PM
Last Post: Kid Karola
  Jonny's Levin Racecar Jonny Rochester 9 11,958 01-03-2010 04:34 PM
Last Post: woper
  Another AE86 build up - Racecar Jan Pedersen 18 20,208 06-09-2008 03:34 PM
Last Post: Jan Pedersen
User(s) browsing this thread: 14 Guest(s)
