SAFC II on a 4ag 20 valve (silver top)
03-07-2007, 01:33 AM
Some of my friends are telling me I should buy a SAFC II for my Levin 4ag 20v silvertop project. So far the 4ag has a port & polish job, a little more compression than stock (11-1), header and a lightweight flywheel. The thing is I´m not sure that a SAFC will make a difference in the performance of the engine. I would really apreciate your comments
03-07-2007, 06:21 PM
If you need to be sure, get yourself a wideband O2 sensor first.. you cant tune the engine with an SAFC or whatever else you put on it decently without one anyway.
When you have the sensor you´ll be able to see where more fuel is needed easily. For the rest I think an SAFC might be a simple way to tweak the injection a bit if you´ve already got the 20v ecu anyway. I doubt it will need dramatic changes in fueling. FABRICA MI DIEM, PVNC! |
4A-GE valve shim disintegrated | DaLanZhu | 2 | 801 |
04-30-2025 12:54 PM Last Post: DaLanZhu |
4AGE Valve Buckets Scored | Steller Engineering | 2 | 1,441 |
20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 2,187 |
Red top in the ae86 | gh0st | 25 | 14,226 |
08-08-2022 08:43 PM Last Post: gh0st |
Replacing Top Windscreen Moulding | chrisae86 | 2 | 2,702 |
06-18-2022 08:56 PM Last Post: chrisae86 |
