SAFC II on a 4ag 20 valve (silver top)
03-07-2007, 01:33 AM
Some of my friends are telling me I should buy a SAFC II for my Levin 4ag 20v silvertop project. So far the 4ag has a port & polish job, a little more compression than stock (11-1), header and a lightweight flywheel. The thing is I´m not sure that a SAFC will make a difference in the performance of the engine. I would really apreciate your comments
03-07-2007, 06:21 PM
If you need to be sure, get yourself a wideband O2 sensor first.. you cant tune the engine with an SAFC or whatever else you put on it decently without one anyway.
When you have the sensor you´ll be able to see where more fuel is needed easily.
For the rest I think an SAFC might be a simple way to tweak the injection a bit if you´ve already got the 20v ecu anyway. I doubt it will need dramatic changes in fueling.
  4AGE Valve Buckets Scored Steller Engineering 2 981 10-06-2023 05:34 PM
Last Post: Steller Engineering
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 1,491 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  Red top in the ae86 gh0st 25 11,519 08-08-2022 08:43 PM
Last Post: gh0st
  Replacing Top Windscreen Moulding chrisae86 2 2,173 06-18-2022 08:56 PM
Last Post: chrisae86
  Question about 4AG 20v Engine Block CHACAMAN 1 1,747 06-10-2022 05:17 PM
Last Post: oldeskewltoy
