SOME 4AG valve spring specs
04-30-2015, 09:48 PM
![]() As per FSM specifications(AE86 and AE92) 4AG valve springs are to be checked @ 34.7mm(1.366") 1.366" (34.7mm) This is our standard. All spring were brought to this point, and from this point on coil bind was found. On advice from Loynings, .050" off coil bind is maximum "allowable" VALVE lift. I capitalized VALVE lift because it is different from cam lift* in this situation. From an unknown source - Quote:some valve spring information... *Coil bind doesn't change - with heating, valve stem length can "grow", but with the stems "growth", so will the spring, BUT when compressed, the coils will still bind at the same point - thus for purposes of valve springs - valve lifts, and not cam lifts are being referred too. OEM stock (USED) - 35#s @ 34.7mm(1.366"), full bind comes in @ .349", subtract .050" and you are left with .299" before "effective coil bind". Pressure @ "effective coil bind - 96#s - Spring was bound @ 1.017"
HKS - 30#s @ 34.7mm(1.366"), full bind comes in @ .415", subtract .050" and you are left with .365" before "effective coil bind". Pressure @ "effective coil bind - 120#s - Spring was bound @ .951" Toda - 42#s @ 34.7mm(1.366"), full bind comes in @ .419", subtract .050" and you are left with .369" before "effective coil bind". Pressure @ "effective coil bind - 128#s - Spring was bound @ .947" BC 7MG valve spring - 58#s @ 34.7(1.366"), full bind comes in @.486", subtract .050" and you are left with .436" before "effective coil bind". Pressure @ "effective coil bind" 168#s - Spring was bound @ .880" Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-01-2015, 09:47 PM
I wonder what spec my Supertec springs would reach especial considering I got around .4" of valve lift (can't remember the exact number from top of my head right now).
AE86 ex-daily |
05-02-2015, 01:10 AM
(05-01-2015 09:47 PM)Bean Bandit Wrote: I wonder what spec my Supertec springs would reach especial considering I got around .4" of valve lift (can't remember the exact number from top of my head right now). Got a vice? slip the spring in the vice and close the vice... bind is when the vice stops.... measure between the jaws of the vice.... wont tell you spring pressures, but will tell you bind, and the rest you can work backwards.... Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-02-2015, 10:47 AM
(This post was last modified: 05-02-2015 10:49 AM by Project D.)
For Supertech:
-SPR-TC25S (single):
SPR-TC25D (double):
So @ 10mm (.4"), if it's at valve lift (cam lift minus clearance) single: 582.5N (131lbs) double: 884.7N (199lbs) oldeskewltoy Wrote:Got a vice?Someone migh have seen my pictures on Club4AG facebook group ![]() https://www.facebook.com/groups/Club4ag/...616589697/ |
05-02-2015, 05:57 PM
(This post was last modified: 05-02-2015 05:59 PM by oldeskewltoy.)
(05-02-2015 10:47 AM)Project D Wrote: For Supertech: So they are 14.4mm of lift @ bind using Supertech retainers? (35.4 minus 21) Additionally... aftermarket retainers can offer some lift advantages... but we begin to mix up specs by mixing in none stock retainers. The Supertech springs under a stock retainer would be 34.7mm and bind is @ 21, so the Supertech springs under a stock retainer allows 13.7mm of lift before bind. What does Supertech recommend for maximum valve lift? (Do they abide by .050", or do they have less gap between bind and max lift like the Toda springs are alleged? Other methods of gaining some lift is to machine the spring pocket, this will lower the spring and accommodate more lift. At some point spring bind falls away and the next clearance issue is the .060" that is recommended between the retainer, and the seal @ full lift. Again SOME room can be gained here by machining the top of the guide a few thousandths Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-04-2015, 01:17 PM
(This post was last modified: 05-04-2015 01:33 PM by Project D.)
Yes 14.4mm @ bind
And Supertech don't specify anything about maximum recommended valve lift. I guess mainly because they know that you can't go even close to 14.4mm on the 4AGE head. (The wildest camshafts on the market for the 4AGE 16v are all under 12mm) As a side note, the OEM springs are progressive while all the aftermarket (that I can think of at least) are linear. BTW, I'm surprised you reach coil bind @ almost 26mm (1.017") with the OEM spring. When I tested mine (on a vice) I was @ 25mm (0.985") |
4AGE Valve Buckets Scored | Steller Engineering | 2 | 1,054 |
20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 1,620 |
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 1,813 |
HKS valve springs | totta Crolla | 3 | 2,464 |
AE86 Battery specs | hachirokuGTV | 9 | 17,340 |
03-13-2020 04:16 PM Last Post: Power_uP |
