4AGE 20v Ignition Lead Length
09-25-2014, 03:01 PM
(This post was last modified: 09-25-2014 03:03 PM by mad.matt.)
Hi Guys,
I'm going down the route of S-86 dizi relocation but I need to have some ignition leads made up (don't have the original leads unfortunately). I'll be having magnecor make a set up for me but one of the leads needs to be longer (as well as switching 2-3 on distributor end vice versa). There's no point in spending so much on factory leads when I can have competition leads made up for cheaper and bespoke to my application! Does anyone have factory lines that they can measure for me please or know how much longer the extended lead is? From center of connector to connector across the top. Please see here: http://www.magnecor.co.uk/userfiles/file...ss2011.pdf It's greatly appreciated! Thanks, Matt |
09-25-2014, 03:31 PM
(This post was last modified: 09-25-2014 03:32 PM by pack.)
I can measure them for you!
![]() I bought the bigger cable from samQ just for turning the engine on... Later on i will buy a set of Ultra cables (that don't need anything.... they are big enough) |
09-25-2014, 05:56 PM
(09-25-2014 03:31 PM)pack Wrote: I can measure them for you! Thanks Pack! It's appreciated. If the Magnecor leads have enough extra length (I know some aftermarket ones do) I might be fine but otherwise I'm assuming an extra 30mm should do it ![]() |
10-01-2014, 03:43 PM
And solved
Ignition switch plug and wires | Blaze0010 | 3 | 509 |
Rear arm length | totta Crolla | 7 | 1,368 |
06-05-2024 08:53 AM Last Post: totta Crolla |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 13,871 |
extracted freedom ecu 16v ignition map | ditn | 7 | 9,176 |
[Tutorial Video] Setting 4A-GE Ignition Timing | Homem Bomba | 0 | 5,601 |
