Sensor behind 4th cylinder?
07-22-2005, 11:58 AM
There is a sensor at the back of engine (behind 4th cylinder) connected with two vacuum hoses.
I’m not sure what is the function of this sensor. Can somebody explain me the function of this sensor?
Fun is not the straight line!
07-22-2005, 12:05 PM
Maybe u r talking about MAP sencor vacuum ... right?
07-22-2005, 12:12 PM
max_ae86 Wrote:There is a sensor at the back of engine (behind 4th cylinder) connected with two vacuum hoses.
.. please post a picture
Kris
07-22-2005, 04:07 PM
Here is picture
07-22-2005, 06:14 PM
is this located in an AE82 GTi / Ae86 or an Ae92 ?
I do not have the ?-marked pipe(hoseing)
the sensor is what i bealive an sensor fot the heater.
07-22-2005, 07:34 PM
That's an exhaust gas recirculation pipe. I think I have that little thingy left from my ae92 engine too.
07-25-2005, 08:31 AM
Yes, it’s an EGR pipe. Engine is from AE92 fwd (with TWIS and AFM). But I don’t understand the function of this sensor near pipe. It has something to do with temperature, maybe? I try to find it in 4AGE manual, but there is nothing about this sensor.
07-25-2005, 08:57 AM
I took off everything that was different from the ae86 engine before installing my ae92 engine. How did you get the EGR pipe to fit the ae86 exhaust manifold? Or did it come with EGR from the factory?
You could try looking up the ae92 gti in EPC and find the part in the engine and drivetrain section, there you should be able to find a short description.
07-25-2005, 10:09 AM
Ivan141 Wrote:I took off everything that was different from the ae86 engine before installing my ae92 engine. How did you get the EGR pipe to fit the ae86 exhaust manifold? Or did it come with EGR from the factory?
I bought it like that. Ex owner replaced the engine from AE92, so I’m not introduced with all details. I will check those EGR pipes and take a few pictures.
So, you took out everything what is different from regular AE86. Did you have this sensor at the back?
07-25-2005, 11:38 AM
Cant remember, I think so...have to look in the barn at my parents house next weekend to confirm that.
  4AGE cylinder head plug removal Ivan141 5 1,964 09-30-2023 09:47 PM
  Lambda sensor wiring sam3007 10 4,186 05-23-2022 10:00 PM
Last Post: The Doctor
  Brake advice - master cylinder mannix20vt 12 13,842 08-21-2017 03:21 PM
Last Post: Project D
  Shifting from 4th to 3rd pack 7 6,122 04-27-2017 07:26 PM
Last Post: totta Crolla
  Correct connection brake master cylinder? bozu 5 7,146 07-26-2015 12:28 PM
Last Post: bozu
