Server outage on Friday 13th
06-13-2008, 02:17 PM
We had some server problems last night. After 2:00 am CET the server hanged and we could not reach it anymore. It must have been because today is Friday 13th! Angry
Normally we have serial console access and a powerbar to powercycle the machine. Serial console didn't give me access since the machine hanged completely and the powerbar failed in shutting off the power.
Today someone from the hosting party manually restarted the server at 13:50 so it's back online and we only had just less than 12 hours of downtime! Hurray!
Thanks to Niels for going through the trouble! Thumbs up!
[Image: AEU86 AE86 - Server outage on Friday 13th]
06-13-2008, 02:24 PM
good work Smile
i'd suggest check the log files and see whether the linux kernel was killing random processes, and whether apache was potentially hogging all resources causing extreme loads.
I remember having a load of 29+ on one of our servers, luckily sshd wasn't killed (yet), it just took about 15 minutes for the shell prompt to arrive, and then some blindtyping and hoping things would work out with a simple apachectl (apache2ctl?) graceful to hotwire apache again Big Grin
Grin.
Oh hey banpei, bit offtopic, but i noticed you were on IRCnet too? Big Grin
06-13-2008, 04:23 PM
Same error as before: one of the harddisks failing (disappears) and then the RAID failing due to this. However it is set up as a mirror, so it should just continue like nothing is wrong but in reality it hanged the system.
Howerver there is one difference now: during startup the second harddisk failed again and now it's running raid on only one disk. Better check that out this weekend...
06-13-2008, 04:29 PM
ouch, at least you guys are running a raid Hurray!
good luck with fixing! i/o troubles suck even more
  13th Annual Retro Toyota Gathering UK Nismo 1 1,620 07-19-2023 09:36 AM
  Server crashed last sunday banpei 17 18,198 10-25-2012 11:15 AM
  Slight problem with the server banpei 4 6,158 05-31-2009 09:34 AM
  Server problems banpei 4 6,176 06-10-2007 09:27 PM
Last Post: Lipinhu
  Server problems Mux213 10 10,094 01-04-2007 11:43 PM
