Settings for APEXi SAFC???
04-26-2005, 10:19 PM
Has anybody ever used or heard about setting up an APEXi SAFC in a normal AE86?
Thanks AE86 FANATIC!!! |
04-26-2005, 11:11 PM
I have one in my car, i must say that you need a dyno run to set it up. My advise is that you dont mess with the settings before you have done everything to the engine that you want to do. Such as sharper cams, flowed ports in head, exhaust system and so on... The SAF-C is the last polish on the engine tuning, and has to be done on a dyno.
04-27-2005, 12:08 AM
You can download english (and maybe other languages) from their website.
04-27-2005, 12:38 AM
Do they have such kind of info there? Not the wiring and connections but tunning settings i mean?
AE86 FANATIC!!! |
04-27-2005, 12:52 AM
You just add or remove fuel. S-AFC ain't a Motec you know.
Broken down 1984 Trueno HB ![]() |
04-27-2005, 09:58 AM
But you have to beware of the consequenses by adding or removing fuel...Your engine can die on you if you give it to much or to little fuel...
![]() Youtube Myspace and I´ll Google your Yahoo |
04-27-2005, 07:41 PM
It won´t die if you give it too much,but it will if you make it WAY to lean.
Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
04-27-2005, 11:18 PM
I dont quite understand the question...an SAFC is not a tuning part in the simple sense of the word. It allows you to optimise performance AFTER making changes to the engine (compression, turbo, cams, itb's etc..). It will have no positive effects on an otherwise stock engine.
And as the previous posts say, even if you changed the engine enough to put the SAFC to good use, you will need to dynotune it for best results (wideband lambda equiped dynamometer preferably). FABRICA MI DIEM, PVNC! |
04-27-2005, 11:23 PM
Well it is in my hands so why not to use it?
![]() Any suggestions not to make the engine "WAY too lean" as Denmark said? Thanks to all for your interest... ![]() AE86 FANATIC!!! |
04-27-2005, 11:29 PM
Well with a stock engine don't change the settings. And when you do change the settings just make it richer not leaner. I don't think you need to make the engine run leaner.
Torque settings | kazi | 4 | 8,363 |
03-28-2017 12:15 AM Last Post: kazi |
What do you guys think of the APEXi SAFC-II system? | heshan | 2 | 3,954 |
02-28-2009 10:32 PM Last Post: heshan |
Settings for HKS 256 cams on stock engine | Bean | 7 | 8,917 |
03-16-2008 10:56 AM Last Post: Bean |
How to improove oem WHEEL ALIGNMENT settings (toe&caster | Apolan | 13 | 14,568 |
03-12-2008 02:58 PM Last Post: Roku_trueno |
Apexi Power FC | Thor W | 3 | 5,214 |
09-29-2007 12:42 AM Last Post: SYM |
