How to improove oem WHEEL ALIGNMENT settings (toe&caster
03-09-2008, 11:42 PM
Lets talk about this. I'm wondering if oem alignment can be adjusted to perform better (fast street use). I will be running just sporty lowering springs and sporty shocks. Cca 40mm lowering (no coilovers).
[u:cba0d06625]OEM Specifications:[/u:cba0d06625]
caster: 3°40'
toe: 1mm toe in after 180° advance of the wheels
Probably best to leave toe oem for street, as we dont want to torture our tires too much. But how about caster setting? 3°40' doesn't seem alot, so how much can be gained by increasing the caster?
PS: how about TIRE PRESSURE? the manual says OEM inflatation should be 1.7 bar (24 psi). What combinations have you tried and experience?
regards,sašo
03-10-2008, 12:05 AM
i am using 30psi for 185/60-14 tyres...
03-10-2008, 12:06 AM
what are your impressons?
03-10-2008, 12:26 AM
seems very good!
03-10-2008, 12:49 AM
apo i was running no toe in just complete striaght on 2.2 bar front and 2.1 bar rear on 205x50x15 which I thought was for that setup of tires a very nice way to drive the car
03-10-2008, 09:12 AM
I was actually thinking about just this. I changed ride height and need to adjust toe before going to the Ring. I found this on the subject:
Quote:Now to get back to tire wear. It is not the camber settings that prematurely wear out tires (unless you never drive your car hard enough) but the toe setting. The toe setting will change with any suspension change you make and is mandatory to be adjusted after any change to the front suspension. The easiest way of adjusting this is by picking up a set of toe plates. They are just 2 pieces of metal that you put against your wheels with a tape measure slots built in. I just set my toe to 0 but you can give it safely about an 1/8inch in ether direction (ie tow out= autocross, toe in= high speed stability).
*Battleversion suspension guide @ club4ag*
After talking to my friend who used to rally his AE86 I decided to try 0.5 mm toe in.
[Image: AEU86 AE86 - How to improove oem WHEEL A...amp;caster]
03-10-2008, 10:01 AM
im running 2.2 front and rear in 195/50-15 and still the shoulders of the tire wear more, but handling is very good.
Thinking to try in 2.3 or 2.4 next time.
03-11-2008, 08:07 PM
Tire-pressures are very tire dependent..not much use stating them without any background info.
03-11-2008, 08:58 PM
NoHachi Wrote:Tire-pressures are very tire dependent..not much use stating them without any background info.
I guess your right. 2.4 in a toyo proxes T1R is to hard. Had more understeer at the front... gonna put them back to 2.2
03-12-2008, 12:38 AM
good info. so slight toe out gives more responsive steering and produces more oversteer? in which phase of the corner?
And how about the caster, has anyone tried increasing it? NoHachi, you're our tech specialist, your thoughts? Big Grin
  Torque settings kazi 4 7,489 03-28-2017 12:15 AM
Last Post: kazi
  Lower arm hits toe arm on lock... fullybuiltmiata 12 14,204 01-14-2016 11:52 PM
Last Post: Deuce Cam
  What is normal and low caster in Cusco camber plates?? T_AE86 9 15,669 01-07-2016 02:56 AM
  alignment issues after re-install of coilovers NBU 21 19,854 08-03-2013 06:18 AM
Last Post: allencr
  Street wheel alignment. Aram 11 12,636 03-31-2013 04:24 PM
Last Post: Aram
