Street wheel alignment.
03-25-2013, 09:23 PM
Hi,
I'm looking for a good street alignment for my car.
I tried a search but all that turns up is drift alignments.
The local garage only has the fwd AE82 alignment on hand. Sad
03-25-2013, 09:35 PM
-1/-1,5° camber, 3-4° caster, 0 toe
No Smorking AE86
03-26-2013, 08:32 PM
Ok, thanks mate. Smile
Is this from the manual or your own experience?
03-26-2013, 08:47 PM
I've been driving with the same setup since last summer. Except my camber settings are around -2°. Car sticks on the road. Thumbs up!
ハチロク
[Image: AEU86 AE86 - Street wheel alignment.]
03-26-2013, 08:51 PM
You dont have extra tyre wear with -2 camber?
03-26-2013, 09:00 PM
I run -2 degrees camber, 3.5 degrees caster, o degrees toe. no excess tire wear and real responsive.
03-26-2013, 10:39 PM
Aram Wrote:You dont have extra tyre wear with -2 camber?
A little but nothing excessive.
ハチロク
03-29-2013, 07:49 AM
2.5 camber
2.5 caster (if manual rack) 3.5 caster (power rack)
0 toe. or 1mm toe in.
Toe is what wears tires fast. Camber not so much.
Andrew
03-29-2013, 11:35 AM
From own expercience, you can add a bit of negative camber for sportier driving, but this was my daily driving setup.
No Smorking AE86
03-29-2013, 12:41 PM
Toe depends on the bushings used as well
Big low offset wheel + rubber bushings = big moment of contact patch drag component around + rubber compliance = toe-out at speed and under braking.
  alignment issues after re-install of coilovers NBU 21 21,891 08-03-2013 06:18 AM
Last Post: allencr
  street quiet exhaust ? Uzelac 18 31,244 11-21-2012 04:32 AM
Last Post: clooney
  How to improove oem WHEEL ALIGNMENT settings (toe&caster Apolan 13 15,038 03-12-2008 02:58 PM
Last Post: Roku_trueno
  Street Tires - your choice? Apolan 19 19,642 02-17-2008 11:38 PM
Last Post: The Doctor
  Quick Help for street springs rate. oldskull 14 16,070 02-02-2008 09:12 PM
Last Post: oldskull
