Street wheel alignment.
03-25-2013, 09:23 PM
Hi,
I'm looking for a good street alignment for my car. I tried a search but all that turns up is drift alignments. The local garage only has the fwd AE82 alignment on hand. |
03-25-2013, 09:35 PM
-1/-1,5° camber, 3-4° caster, 0 toe
No Smorking AE86 |
03-26-2013, 08:32 PM
Ok, thanks mate.
Is this from the manual or your own experience? |
03-26-2013, 08:47 PM
I've been driving with the same setup since last summer. Except my camber settings are around -2°. Car sticks on the road.
ハチロク |
03-26-2013, 08:51 PM
You dont have extra tyre wear with -2 camber?
03-26-2013, 09:00 PM
I run -2 degrees camber, 3.5 degrees caster, o degrees toe. no excess tire wear and real responsive.
03-26-2013, 10:39 PM
Aram Wrote:You dont have extra tyre wear with -2 camber? A little but nothing excessive. ハチロク |
03-29-2013, 07:49 AM
2.5 camber
2.5 caster (if manual rack) 3.5 caster (power rack) 0 toe. or 1mm toe in. Toe is what wears tires fast. Camber not so much. Andrew |
03-29-2013, 11:35 AM
From own expercience, you can add a bit of negative camber for sportier driving, but this was my daily driving setup.
No Smorking AE86 |
03-29-2013, 12:41 PM
Toe depends on the bushings used as well
Big low offset wheel + rubber bushings = big moment of contact patch drag component around + rubber compliance = toe-out at speed and under braking. A wheel to steer the front of the car A pedal to steer the rear |
alignment issues after re-install of coilovers | NBU | 21 | 18,965 |
08-03-2013 06:18 AM Last Post: allencr |
street quiet exhaust ? | Uzelac | 18 | 28,262 |
11-21-2012 04:32 AM Last Post: clooney |
How to improove oem WHEEL ALIGNMENT settings (toe&caster | Apolan | 13 | 12,690 |
03-12-2008 02:58 PM Last Post: Roku_trueno |
Street Tires - your choice? | Apolan | 19 | 16,923 |
02-17-2008 11:38 PM Last Post: The Doctor |
Quick Help for street springs rate. | oldskull | 14 | 13,895 |
02-02-2008 09:12 PM Last Post: oldskull |
