Short stroke suspension
10-11-2012, 11:45 AM
Take a look here Lajos, those GAZ dampers should suit your rates very well, are adjustable through a large range and should be a decent length for AE86s
http://rallyspares.tripod.com/id74.html
Or
http://www.ebay.co.uk/sch/i.html?_nkw=es...&_osacat=0
Send them a mail about the attachment method and their lengths. At 75€ each new you won't find a better deal around or a better match to the ae86 chassis.
10-13-2012, 06:09 PM
Lajoosh Wrote:need info and axperience on this.
i have been planning to build coilovers all around for an 86 with adjustable konis, ae92 insert on the front, ae86 oem stroke on the rear. but i dont like tha fact that i have to push and turn the rear shock to adjust damping, as i would have to disassemble the coilover every time i need to make an adjustment. so im questioning, what if i would use ae92 front inserts for the rear too? lenght is good, mounting eye not a problem.
whats your opinion guys?
My opionion, fronts whould work alright even tho I personally I dont like konis at all, cause of the stupid internal adjustment.
Using them at the rear? Bollocks.
You need serious short stroke shocks for the rear to get the most out of your coilovers, I´ve just gone rear coilovers and the cost about 320GBP build my specs with a sperical bearing and shorter than TRD blue shocks
Bit more info in my build thread:
http://www.aeu86.org/viewtopic/my-slowly...0/start=50
As we´re talking about GAZ shocks, the company I work for does a lot of custom supensions with them, they build us whatever we require, lenghts, diameters, mounting points... so literally anything is possible. I know what your company does, but I doubt by the end with buying AE92 fronts, springs, faffing about with getting it to work, you´ll waste time and probably end up more expensive. You´re much better of just to buy a set.
If you intrested Pm me and I give you an acurate quote. Thumbs up!
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
  TRD Short Shifter Rattle Noise, It's Normal? Mattolo 19 20,831 04-27-2024 10:04 PM
  Bilstein short strokes Grant 1 4,366 05-15-2012 07:32 PM
Last Post: NoHachi
  Does anyone know where to buy a short steering hub/boss? krullibull 6 6,942 10-12-2011 10:26 PM
Last Post: krullibull
  Long Stroke Springs - Espelier 40mm Tokico ??? juantonwan 20 18,063 05-11-2010 10:31 PM
Last Post: jondee86
  fc3s front brake conversion, short report speed-inc 18 16,812 10-09-2009 06:32 AM
Last Post: aussiefan
User(s) browsing this thread:
