TRD Short Shifter Rattle Noise, It's Normal?
05-05-2015, 06:03 PM
Hi to all, just one week ago I mounted a new TRD Short Shifter kit.
When I arrive at 5000 RPM in any gear, from T50 coming out a rattle noise. It's Normal? |
05-05-2015, 07:48 PM
If it's the shifter rattling then you might need a new bushing on the bottom of it....
05-05-2015, 10:45 PM
IIRC the TRD shifter doesn't have any bushings inside the assembly. The shift lever pivots on the casting. It's supposed to provide a more direct feel at the expense of nvh. I've never had one but from what I understand they're known to rattle.
05-06-2015, 09:01 AM
(This post was last modified: 05-06-2015 09:02 AM by Ivan141.)
There is supposed to be a bushing around the little ball at the end of the gear lever where it slots into the gearbox. It's an OEM part which is often worn out, causing the shifter to have too much slack.
I think T3 even made delrin replacement bushings for it. https://technotoytuning.com/toyota/ae86/...86-corolla FABRICA MI DIEM, PVNC! |
05-06-2015, 10:00 AM
(This post was last modified: 05-06-2015 10:01 AM by Mattolo.)
The bushing it's included in new kit, I'll try it, cusco bushing:
05-07-2015, 01:18 PM
ok, I tryed to mount the cusco bushing kit, the rattle noise it's reduced, but it exist.
I read on the web that a solution maybe a Shift knob heavier? |
05-07-2015, 01:42 PM
I've been successful using foam rubber packed inside the shifter boot. You could also try adding solder warped around the shift lever. [ at the top] Keep adding more until you change the natural frequency, of the lever. If that works, then you should try finding a shift knob with approximately the same additional wt. Dave W
05-07-2015, 07:40 PM
Yes, it's normal, that's why I installed one and removed the day after... Too much race environment for me.
Enviado do meu AiFone Keeping the AE86 alive! |
05-08-2015, 01:03 PM
(This post was last modified: 05-08-2015 01:03 PM by Mattolo.)
(05-07-2015 07:40 PM)Rasteirinho Wrote: Yes, it's normal, that's why I installed one and removed the day after... Too much race environment for me. I think that the TRD Short Shifter It's not for daily use..... for now I leave it installed until I'm going crazy for rattle noise ![]() ![]() thank you guys for your advices! |
05-08-2015, 11:45 PM
TRD shifter stripped of all extra weight for racing...
![]() C's short shifter reputed to be the best AE86 shifter money can buy... ![]() ... and the C's shifter does not rattle ![]() Cheers... jondee86 |
Clicking noise from glove box | chrisae86 | 4 | 2,324 |
09-08-2022 11:36 PM Last Post: chrisae86 |
Noise Insulation for AE86 | decryphe | 1 | 4,267 |
11-03-2016 11:51 AM Last Post: mad.matt |
What is normal and low caster in Cusco camber plates?? | T_AE86 | 9 | 15,760 |
01-07-2016 02:56 AM Last Post: Deuce Cam |
Whining noise HELP PLEASE | izanagi | 10 | 12,835 |
03-26-2015 06:48 PM Last Post: Komba |
Whining noise only in 4th & 5th. | izanagi | 7 | 11,237 |
09-25-2014 07:09 PM Last Post: Uzelac |
